3 members (Hotrod Lincoln, DadsFirstPickup, Otto Skorzeny), 137 guests, and 4 robots.
Topics128,148
Posts1,056,810
Members48,454
I have a pair of rear AD bumper braces I would like to list on the Stovebolt.I know there is a difference between the 1/2 and 3/4 ton.
So how can I tell which is which?
Are you sure there is a difference? If so, it is probable that you couldn't tell them apart unless you had both side by side. For the most part 1/2 and 3/4 ton trucks had the same parts. I have a set out in the garage and I can't find any numbers on mine. They might or might not be originals, I picked them up at a yard sale of all places.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
The 3/4 ton rear brackets are 2" in height and the 1/2 tons are about a quarter inch or so shorter in height.
They are different shapes because of the difference in frame width between the two models. 3/4 ton frame is narrower.
Steve
'49 3800
'52 3600
'57 3100
Thank you Ghostrider.
These measure 1 3/4" across the flat side of the bars so must be 1/2 ton as would be most common.
Thank you.
I have a set of rear bumper braces and they do not fit on my 1/2 ton. I was told there is a difference between the 1/2 ton and 3/4-1 ton rear bumper braces. When I brought this up others say bologne.
Thank you
Dennis
Dennis,
I'd say (and the Master Parts Books says) those other people are full of baloney: for all A-D years, the bumper brackets are differ for 1/2 ton and 3/4 ton and 1 ton trucks (7.836, below).
http://chevy.oldcarmanualproject.com/1929_54chevyparts/07/449.HTM
PICTURES Hard to see the differences, but they do not interchange according to Jim carter.
Thanks to all.
Dennis
Leo Offline
Moderator
Moderator
Maybe they're panel or burb braces.
Originally Posted by TooMany2count
Dennis,
I have a question since I can't make heads or tails out of the above page.
Since the rears are different from 1/2ton to 3/4-1ton does the same go for the front bumper brackets also????joe
According to Jim Carter, they are the same: Bumper Braces Front 1947-Early 1955 1/2, 3/4, and 1 Ton
Unless I am reading the Master Parts book incorrectly (quite possible), it looks like the 47-53 1/2 ton and 3/4 bumper brackets are the same on the front and the 1-ton is different (7.836). Also, the 1954 front brackets look to be different from earlier front bracket??
