0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 138 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 138 | I know I have seen this before but I could not find it in the archives. I just got a brand new front panel for my 57 from a nice guy in North GA and I want to get a primer on it. I will be using Zerorust red oxide for the primer. Should I roughen up the panel as it is? With a orbital sander or will steel wool suffice?
Alex 57' 3100 (The Bondo Bandit) Bad rust and worse wiring, but so much fun.
| | | | | Joined: Sep 2010 Posts: 72 New Guy | | New Guy Joined: Sep 2010 Posts: 72 | Ack! Don't use steel wool! It'll catch everywhere and rust!
Brand new panel - does it have the black primer on it? If so, scuff it well with a Red Scotch Pad, or 320 Grit, clean with Wax and Grease remover, then primer. | | | | | Joined: Jan 2011 Posts: 138 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 138 | Lol yeah steel wool does sound like a dumb idea now. Yes it has that black primer. Thanks
| | | | | Joined: Oct 2011 Posts: 7 New Guy | | New Guy Joined: Oct 2011 Posts: 7 | most of the black /gray primers on reman panels are 'shipping primers' and should be 100% removed, , I have seen adhesion problems with it being left on | | | | | Joined: Jan 2011 Posts: 138 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 138 | I think I am going to go with the red/maroon scotchbrite pad and scuff the hell out of it. I will consider it a test for Zerorust's adhesiveidity. Yes I made that word up.
| | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | I agree with Elderspook on removing the black primer or at least sanding as much off as possible. | | | | | Joined: Oct 2011 Posts: 7 New Guy | | New Guy Joined: Oct 2011 Posts: 7 | when we panel prep at the shop, the only time we use red scotchbright is right before we paint, it is the second to the last abrasive we use the fine , red , pads are equal to about 320 grit the gray pads (ultra) are are the last and they are equal to about 400 the only time we use that on existing surfaces are on a fairly fresh paint. | | |
