6 members (37 GC, klhansen, Shade Baby, Reftys49, MaxStewart, Philipj), 95 guests, and 1 robot.
Topics128,143
Posts1,056,786
Members48,454
#792476 10/26/2011 7:31 PM
0
0 Offline
Hello,
I tested the radio on the bench and it turns out that it works. I found 2 power wires. Where do I plug the one in that just turns on the light? Do I connect it to the gauges or with the other power wire? Also is there anything I should do to the radio before installing it? Its still six volts and it looks to have all the original wiring in it.
Chris
1950 chevrolet 3100
1951 chevrolet suburban carryall
The lamp wire connects to the light switch, the original radio wire had a fuse holder that screwed on to the amp meter, many times these have been replaced or missing as most people couldn't figure it out! .If this radio has not been serviced in many years ,IT WILL NEED it! at least a new buffer, trying to play it as is could cause futher damage, I do JIM CARTER's CLASSIC TRUCK PARTS radio work ,I've had to do many a radio repair on damage that could have been avoided, if the set had been properly restored first.
BILL #792511 10/26/2011 9:51 PM
I connect the radio light-bulb wire to a dash light wire, that way they dim when you dim the dash lights. In 1954, I think that the accessory clock's light-lead came with a "vampire" clamp to attached to the a convenient "rheostated" dash-light lead.
0
0 Offline
Thanks guys for the informaion! Bill, what do you recommend I change to not cause damage?
Chris
1950 chevrolet 3100
Your wax condencers start with the buffer,goes across the rectifier, .006mf at 1600 volt, then check your electrolycs, filters.
BILL #793261 10/29/2011 3:19 AM
0
0 Offline
Wow youll have to forgive me. I have no idea what any of that stuff is. Where is the best place to purchase all of this stuff?
1950 chevrolet 3100
Here's a link to an absolutely great site, by Phil Nelson.
http://www.antiqueradio.org/begin.htm
Your local library should have some books about radio restoration, and Phil even lists some.
I might sound like the nerd that I am here when I say that its quite a thrill to here Perry Como start coming out of the radio.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
If you look at the chassis of the radio where all the components are mounted, you will see round cylinder shaped objects, usually yellow in color and covered in wax. These are the paper capacitors. There are also some other types but I can talk about them later. If you get a circuit of the radio, each of these capacitors is listed in the parts list, the circuit diagram shows where they are connected and usually there is a diagram of where they are on the chassis. These are usually replaced because they dry out and short. Quite a few members here have successfully done this work on thier truck radio. We have walked some of them through the process and helped when they are stuck.
I buy my capacitors from a place on the net called "just capacitors". The rest of my parts I usually get from Antique electronic Supply. If you want to give it a go, I would be glad to help you out, on the site here.
1951 1 Ton Completed
0
0 Offline
Thanks for the link! Ill see if I can locate some circuit diagrams. So these are the things to change out:wax condencers,buffer,electrolycs,filters and capacitors. Correct me if im wrong. Thanks again for your help.
Chris
1950 chevrolet 3100
Does your radio have a back that has a slanting parting line along the sides? If so, here is an online version of the manual.
Online 47 Radio Manual . If your radio has the straight vertical parting line, let me know and I will see if I have a scan of the manual.
Condenser=capacitor
buffer=specific capacitor
electrolytic=specific kind of capacitor
filter=capacitor (often electrolytic, in power supply)
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1926 Model TT Truck
Just to add some more to this description, the electrolytic capacitors in this radio reside in a metal can that is attached to the chassis. The "buffer" capacitor resides under the metal cover, in the vicinity of the vibrator and 0Z4 tube. This particular capacitor has a voltage rating musch higher than the rest, usually around 1600 volts.All the yellow wax covered capacitors are rolled paper capacitors and they should all be treated as suspect.
The reference I made to the online radio manual above is incorrect. That radio is the 1951 to 53 radio, model 986443. The circuit is different than the 1947 to 50 radio. My apologies.
0
0 Offline
Thanks guys for the info. Truckernix is kind enough to help me out with rebuilding the radio. Anyone have the scans for the 986067 radio. Im going to order the one from the parts dealers but would like to get started as soon as I can.
Chris
1950 chevrolet 3100
Moderated by  truckernix
