4 members (Steelonsteel, TooMany2count, 6inarow, klhansen), 86 guests, and 1 robot.
Topics128,035
Posts1,055,552
Members48,425
#79304 06/28/2007 1:40 AM
i know this has been discussed many times but can you just add a remote filter to a 54/235 engine with out any modification? simple answer please. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
#79305 06/28/2007 1:52 AM
Please do asearch on this subject as there are many posts on it and even a Tech Tip.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
#79306 06/28/2007 2:33 AM
The common factory remote filter is only a bypass filter.
Simple to add, even covered in your service manual.
1952 Chevrolet 3800 pickup
---All pictures---
#79307 06/28/2007 2:34 AM
did a search but wanted a more up to date answer, thank you!
2017 Buick Encore
See more pix
#79308 06/29/2007 4:28 AM
The up to date answer is, as stated in other posts, you can convert the engine to full FLOW oil filtration at the time of rebuild by following the instructions in the tech tip.
Without modification you can only use a 'bypass filter' which, unlike full flow filtration, only filters about 10% of the oil.
The shortest answer to your question is:
Yes, you can add a bypass filter without modfying the engine. (this is what Grigg already said).
#79309 06/29/2007 1:42 PM
Is it true that a bypass will only filter 10% of the oil? You're breaking my heart!
~Jim
#79310 06/29/2007 2:33 PM
Ex Hall Monitor
Ex Hall Monitor
I think 10% is an arbitrary number. All of the oil get filtered, just not every trip through the engine. I'm a believer that some trips through the filter are better than no filtration at all.
#79311 06/29/2007 2:39 PM
simple answer:bypass filter=yes....newer filter=no, not without modification
#79312 06/29/2007 3:08 PM
Ron,
Tiny's answer is important. In a by-pass system, all the oil gets filtered, eventually. The by-pass oil filter system works fine. A full-flow filtration system is probably better but is it worth the effort, unless you are setting up your old engine for high-performance operation?
As stated above, the simple answer to your question is: yes, can you just add a remote filter to a 54/235 engine without any modification.
Tim
#79313 06/29/2007 3:26 PM
Big rigs use both full flow and bypass filters for best protection.
Full flow filters only trap the 'larger' particles (20-40 microns and larger) to keep the oil flowing without pressure loss.
These filter systems require a bypass valve either on the filter or engine.
Prevents starving from lack of oil, when the filter gets clogged.
Bypass/remote filters take care of all the very small particles, the full flow filter ignores.
Takes only a few minutes for the entire oil to pass through the filter.
Oil flow is tapped and metered by a small hole at the output, hence the 10-20% amount of flow through it.
Best remote filter is the Frantz system using toilet paper as the element, trapping particles as small as 1 micron !
In business since the 50s with the exact same product.
My new 261 will use the full flow and Frantz filter, for longest engine life.
Even if you change your oil very often - I would recommend to always use clean filters and detergent oil with sufficient zinc content.
While you are at it - tap into the air cleaner bottom as the crankcase breather filter and use a closed valve cover.
The very common breather caps with foam are not very efficient and contaminate clean oil quickly.
The early slotted valve covers give zero protection.
On the road every day...
1952 Truck - 235
1948 Coupe - 261
#79314 06/29/2007 4:31 PM
I have trouble believing the toilet paper thing will catch 1 micron particles. I use a bypass setup with an Amsoil filter. The filter is guaranteed to catch particles to 2 micron absolute. Only 10% of the oil is going thru my filter at any one time but it is 200% cleaner than a full flow filter. I have spin on convenience,no pressure loss,and no block modifications.
Curt B.
You Tube
#79315 06/29/2007 4:56 PM
What impresses me about the Frantz Filter system is the low-tech, cheap and effective principle and that they have been in business for decades with the same product.
Turns out TP filter efficiency is even higher than I remembered.
From the Frantz FAQ page:
It has the ability to remove any Solid Particle down to 1/10 of a micron (.000039")and up to 6 ounces of Water.
I bet there are tests/filter shoot-outs online, proving and disproving claims.
Only personal long-term use will show what works best.
Just good to see the primitive Frantz system on the market unchanged for decades.
1952 Truck - 235
1948 Coupe - 261
#79316 06/29/2007 6:59 PM
Well you got me on the cheap part. An Amsoil spin on bypass filter cost me $40.00. eek Worth it to me as even soot is removed leaving the oil always looking like it was freshly changed.
You Tube
#79317 06/29/2007 7:37 PM
Sounds like both products give very similar results.
The TP also removes water from the oil, which is very nice during the cold months.
If the amsoil filter is washable and reusable for life, the price is alright and beats the price of a new frantz system.
I bought mine NOS and very cheap.
1952 Truck - 235
1948 Coupe - 261
#79318 06/29/2007 11:26 PM
I bought my first Frantz system in 1963 and installed it on my 1955 chevy 265. It worked beautifuly and I will be putting one on my 350 if I ever get it running.
http://www.wefilterit.com/orders/100/index.htm
~Jim
#79319 06/30/2007 2:16 PM
thanks all. ron
2017 Buick Encore
See more pix
