3 members (Gdads51, 2 invisible), 60 guests, and 1 robot.
Topics128,115
Posts1,056,636
Members48,450
I am replacing the brake lines, master cylinder, wheel cylinders, springs and shoes on my 1951 3100.
One of the rear brass blocks that the banjo bolt goes in to is stripped. It looks like I can run a new brake line straight from the junction block to the rear right cylinder and exclude the brass block.
Does anyone know what purpose those blocks serve? Is it OK to eliminate them without sacrificing brake efficiency and safety?
I don't think so Larry. Those wheel cylinders aren’t machined to take a pipe fitting or
inverted flare if that was what you were thinking. Taint like the new ones you know!
The banjo’s are available at a bunch of places from most of the vendors catalogs and your
local auto parts might have them or be able to get them for you the next day.
Also don’t try to reuse the copper gaskets, use new ones or you’ll end up with a leak.
DG
Denny G
Sandwich, IL
Thank you both for the advice. I found a brass block on-line and will replace it as the original was.
