3 members (Nick in Manitou, Hanks custodian, JW51), 106 guests, and 2 robots.
Topics128,062
Posts1,055,854
Members48,428
#79221 06/26/2007 4:35 AM
Hello from Wisconsin! Grant here. I've been thinking of trans swaps for my 59. If I use a Saginaw 4 spd, the shifter is side mounted, causing a bit of tight fit with seating arrangements, and a bit more difficult floor cuts due to supports, etc. A 5 speed, such as S-10 would have, is a top load trans shifter, logic says easier fitment for floor/shifter/seat. Please advise. Grant.
#79222 06/26/2007 4:36 AM
P.s. I am running stock 235. Grant.
#79223 06/26/2007 4:42 AM
I couldn't be more happy with the S-10 T-5 I installed in my 37 Chev pickup behind a 56 261. I think it looks more correct than any other choice I had. I would recommend it!
Joe smile
#79224 06/27/2007 3:31 AM
Hey Joe, thanks for the reply. What is involved with the switch? I have an aftermarket rear trans support, and the newer splined slip yoke at the trans. Clutch, standard or hydraulic? Let me know. Grant.
#79225 06/27/2007 4:30 AM
Hey Grant,
Mongo\'s Garage has done all the research on the T5 swap.
Thanks Mongo!!
Zeke
#79226 06/27/2007 5:03 AM
Zeke knows Grant. A standard clutch.
Joe smile
