2 members (78buckshot, IHPWR),
88
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#79221 06/26/2007 4:35 AM | Joined: Feb 2007 Posts: 56 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 56 | Hello from Wisconsin! Grant here. I've been thinking of trans swaps for my 59. If I use a Saginaw 4 spd, the shifter is side mounted, causing a bit of tight fit with seating arrangements, and a bit more difficult floor cuts due to supports, etc. A 5 speed, such as S-10 would have, is a top load trans shifter, logic says easier fitment for floor/shifter/seat. Please advise. Grant. | | |
#79222 06/26/2007 4:36 AM | Joined: Feb 2007 Posts: 56 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 56 | P.s. I am running stock 235. Grant. | | |
#79223 06/26/2007 4:42 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I couldn't be more happy with the S-10 T-5 I installed in my 37 Chev pickup behind a 56 261. I think it looks more correct than any other choice I had. I would recommend it! Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
#79224 06/27/2007 3:31 AM | Joined: Feb 2007 Posts: 56 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 56 | Hey Joe, thanks for the reply. What is involved with the switch? I have an aftermarket rear trans support, and the newer splined slip yoke at the trans. Clutch, standard or hydraulic? Let me know. Grant. | | |
#79225 06/27/2007 4:30 AM | Joined: Nov 2005 Posts: 144 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 144 | Hey Grant, Mongo\'s Garage has done all the research on the T5 swap. Thanks Mongo!! Zeke | | |
#79226 06/27/2007 5:03 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Zeke knows Grant. A standard clutch. Joe
