| | | Forums66 Topics128,009 Posts1,055,295 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#79079 06/22/2007 4:34 AM | Joined: Feb 2007 Posts: 86 Member | | Member Joined: Feb 2007 Posts: 86 | Calling all rearend gurus. I'm helping my uncle with his '65 C10. It has the original 12 bolt rearend that the spiders just locked up on him. Long story short, he had a grinding in the right rear. When I pulled the wheel off the backing plate was distorted due to the wheel bearing coming unglued and the axle shaft moving up a good 1/4". When I pulled the cover the fluid oozed out like tar. The rest of the bearings don't have any slop but the spiders are siezed to the center pin. I can only drive it out about a 1/2" either way before my drift starts sinking into the pin! (First, I should state the obvious: I did remove the retaining bolt!  ) I've tried heat, PB Blaster and a BFH. I can see where the gears have scored the pin. Does anyone know what year spider gears are compatable with this rearend? He's kinda low on funds right now so we want to go junkyard surfing until he is able to upgrade. I've searched all the sites I know and have only come up with Classic Parts as offering the pin but not the gears. The truck doesn't see much use, but he wants to be able to hit the big cruise at the end of the month. Thanks in advance........ | | |
#79080 06/22/2007 1:52 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Should be a 63-80-ish 1/2 ton truck,,I think 81 was the change to the 10 bolt rearend, get a used center section complete. | | |
#79081 06/22/2007 10:05 PM | Joined: Feb 2007 Posts: 86 Member | | Member Joined: Feb 2007 Posts: 86 | Thanks 64, I'm heading to the yard in the morning, hopefully there are some still out there.
Thanks, Scott | | |
#79082 06/23/2007 2:19 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | You need to make sure of the spline count. GM made a running change in '65 from the 17 spline to the 30 spline. They can be interchanged, but you have to change out the axles, too.
Bill Burmeister | | |
#79083 06/23/2007 4:37 AM | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Be careful, I believe 10 bolt rears were around in 79.
~Jim
#79084 06/23/2007 7:16 AM | Joined: Feb 2007 Posts: 86 Member | | Member Joined: Feb 2007 Posts: 86 | Longbox: Good point on the spline count, I probably would have missed that.
Big Chevy: You're right, my '75 has a 10 bolt.
I was hoping to be able to just replace the entire chunk, buuuuuut... I even broke out the BIGGER BFH today to no avail. There must be a major burr or something on the shaft. I drove the pin out enough to free the washer on one of the gears, but now it's stuck like it was welded. I've been trying to drive the pin back and forth hoping to break past the burr or whatever it is, but now I have it jammed and have to wait till morning to break out the die grinder because I mushroomed the top of the pin. My uncle found a place locally that sells the replacement spiders and pin for $99. At this point I'm about to take the blue tipped wrench to it and say the heck with it and have him buy the replacement kit. Although, his truck does look darn good in my driveway, I'd like him to be able to drive it soon.
Has anyone had a gear set sieze up like this on them before? I was just wondering if this a fluke or is this common. I've had them crumble and spit teeth out through the cover before, but never seen one sieze up like this.
Thanks again..... | | |
#79086 06/24/2007 6:05 AM | Joined: Feb 2007 Posts: 86 Member | | Member Joined: Feb 2007 Posts: 86 | I didn't even think about ebay. We finally got the gears out about 11pm. I'm sure my neighbors appreciated the banging and die grinder  . We finally had to have one person hold the drift with channel locks so the other one could use both hands on the hammer. We got the pin out to where it just about touched the case, spun it around, hacked the pin with a cut off wheel, and drove it back down into the spiders and rotated the carrier and drove it back out the 'window' in the carrier. Man,that was too much like work! This one has the 30 spline axles, so hopefully they will be easier to come across. We found all of the passenger side axle bearings along with the race half way down the axle tube and the driver side spit out one bearing and was on its way out too. Thanks so much for all the help, as always that's why this is the best site around! I've been so busy trying to get my wagon ready for Woodward Dream Cruise and haven't stopped in here much lately. Thanks alot, Scott | | |
