| | | Forums66 Topics128,051 Posts1,055,729 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 127 | Now that I have the New Fuel pump with the vacuum booster installed how is it plumbed into the vacuum system to assist the wipers. The booster has 2 ports one marked in and one marked out. The truck has a 90* hose-barb fitting at the intake manifold which is split at a tee one to the trans shift solenoid(turbo 350) and one to the wiper motor. there are two ports on the wiper motor, but I am only using one and it works this way (just not well). Jessica's TruckThe true definition of insanity: To do the same thing the same way repeatedly and expect a different result each time. | | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I ran one line from the pump to the intake. Ran another line from the pump to the wiper. That's all I have for lines, but my wiper motor has issues. I did get good vacuum. | | | | | Joined: Jul 2010 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 127 | Thanks for the info. I will give it a shot. Incidentally does it matter which port goes where. One is marked "in" and the other is marked "out" so i would guess "in" to the intake and "out" to the wipers? Jessica's TruckThe true definition of insanity: To do the same thing the same way repeatedly and expect a different result each time. | | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Thanks for the info. I will give it a shot. Incidentally does it matter which port goes where. One is marked "in" and the other is marked "out" so i would guess "in" to the intake and "out" to the wipers? Air is sucked in to the wiper motor. I would think you need a line from there to the 'in' port on the pump. The 'out' going air would be sucked into the intake. | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Easiest way is to pull a hose off the pump and see if it sucks or blows. If it sucks, it goes to the wipers. If it blows, it goes to the manifold. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Good answer, Roy.
I have seen three different "codes" for the two ports on dual-action pumps: port "1" and port "2"; port "In" and port "Out"; and, no labels at all.
Another good answer was recently posted in response to this conundrum: connect them one way and if it does not work, connect them the other way.
| | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 | Another good answer was recently posted in response to this conundrum: connect them one way and if it does not work, connect them the other way. LOL... Good answer here too! Stay away from rotating elements in the process, though! Jerry | | |
