2 members (Nick in Manitou, walterhvogel), 73 guests, and 2 robots.
Topics128,035
Posts1,055,559
#790723 10/21/2011 12:15 AM
V
V Offline
Now that I have the New Fuel pump with the vacuum booster installed how is it plumbed into the vacuum system to assist the wipers. The booster has 2 ports one marked in and one marked out. The truck has a 90* hose-barb fitting at the intake manifold which is split at a tee one to the trans shift solenoid(turbo 350) and one to the wiper motor. there are two ports on the wiper motor, but I am only using one and it works this way (just not well).
Jessica's Truck
The true definition of insanity:
To do the same thing the same way repeatedly and expect a different result each time.
GMC: Get More Cash...
1958 GMC
My Webshots photos
Leo Offline
Moderator
Moderator
I ran one line from the pump to the intake. Ran another line from the pump to the wiper. That's all I have for lines, but my wiper motor has issues. I did get good vacuum.
V
V Offline
Thanks for the info. I will give it a shot. Incidentally does it matter which port goes where. One is marked "in" and the other is marked "out" so i would guess "in" to the intake and "out" to the wipers?
Jessica's Truck
Yup!
1958 GMC
My Webshots photos
Air is sucked in to the wiper motor. I would think you need a line from there to the 'in' port on the pump. The 'out' going air would be sucked into the intake.
Easiest way is to pull a hose off the pump and see if it sucks or blows. If it sucks, it goes to the wipers. If it blows, it goes to the manifold.
Good answer, Roy.
I have seen three different "codes" for the two ports on dual-action pumps: port "1" and port "2"; port "In" and port "Out"; and, no labels at all.
Another good answer was recently posted in response to this conundrum: connect them one way and if it does not work, connect them the other way.
LOL... Good answer here too!
Stay away from rotating elements in the process, though!
