3 members (Nick in Manitou, Wally / Montana, 1 invisible), 58 guests, and 3 robots.
Topics128,076
Posts1,055,920
Members48,429
And I've still got some priming to do.
We're down in to the 50's now and I'm needing to shoot a bit more primer. Using PPG
DP90LF and K36 over the top of it.
The coolest reducers that I can find are 60°-70° DT860 and I’m wondering if the
hardeners and catalysts are gonna kick off with the temps in the mid 50’s?????
Any real painters out there??
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
I can't answer that cause my bottom temp for painting is 60 degrees and I don't try that often.
If it was me I'd try a little on some piece of junk and determine the outcome.
Speaking of cool, it's 36 this morning down here.
Dan
Remember your freedom - US Veterans provided it.
101st Screaming Eagles
How about an electric radiant heater Denny? You'll have to watch the panel doesn't get too warm, these days its easy to check if you have an infer-red thermometer.
You could take the panel outside, heat, paint, and then take it back inside. Provided its something carry-able.
That's what I've done before when I had to get epoxies and resins to kick off, and paint and varnish.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
my paint guy has a DIY heat lamp fixture, 4 infrared floods on a crossbar that warms up areas quite nicely, any infrared type heater would do what you need, indoors or out [with a wind screen]
You could probably run the engine for a while, put the truck back inside your barn/shop, cover it with some old quilts and it would be nice and warm when you pull them off.
Maybe even warm enough for primer
Dennis
