9 members (ranchojuan, jkreiner, fonz8261, TexasJim50, rfs56trk, Forty9, Bill Hanlon, treegrower, Wally / Montana),
55
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,074 Posts1,055,914 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | And I've still got some priming to do. We're down in to the 50's now and I'm needing to shoot a bit more primer. Using PPG DP90LF and K36 over the top of it. The coolest reducers that I can find are 60°-70° DT860 and I’m wondering if the hardeners and catalysts are gonna kick off with the temps in the mid 50’s????? Any real painters out there?? Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Jan 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 502 | I can't answer that cause my bottom temp for painting is 60 degrees and I don't try that often. If it was me I'd try a little on some piece of junk and determine the outcome.
Speaking of cool, it's 36 this morning down here.
Dan
Remember your freedom - US Veterans provided it. 101st Screaming Eagles
| | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | How about an electric radiant heater Denny? You'll have to watch the panel doesn't get too warm, these days its easy to check if you have an infer-red thermometer.
You could take the panel outside, heat, paint, and then take it back inside. Provided its something carry-able.
That's what I've done before when I had to get epoxies and resins to kick off, and paint and varnish. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | my paint guy has a DIY heat lamp fixture, 4 infrared floods on a crossbar that warms up areas quite nicely, any infrared type heater would do what you need, indoors or out [with a wind screen]
Bill | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | You could probably run the engine for a while, put the truck back inside your barn/shop, cover it with some old quilts and it would be nice and warm when you pull them off.
Maybe even warm enough for primer
Dennis -there is nothing stronger than the heart of a volunteer-
