| | | Forums66 Topics128,093 Posts1,056,046 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 39 'Bolter | | 'Bolter Joined: Feb 2002 Posts: 39 | Apparently this is so easy I can't do it. I bought a new spring for this and have now lost it for the second time. This time for good. How do you put these on so they will stay? Obviously I'm not getting them tight enough so it will stay. I'm afraid if I get it too tight it won't work. Which way do you put it on and which way do you 'wind' it to make it work? Thanks,Scott | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Make sure that you have the old spring out of the slot. If its in far enough it will be parallel to the peg for the hook end of the spring. When installed it should hold light pressure on the plate to the closed position. It is easier if you get the spring put into the slot first, then use a needle nose pliers and put the hook onto the peg. | | | | | Joined: Apr 2010 Posts: 160 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 160 | After the spring is installed pinch the end of the shaft together with a pair of pliers. | | |
