| | | Forums66 Topics128,065 Posts1,055,868 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 22 New Guy | | New Guy Joined: Jul 2006 Posts: 22 | I need information on how to remove and replace the heat tube from the throttle base of a BC carb. I have a carb that is plugged solid with carbon (I'd guess) right where the tube exits the base. I have tried pouring laquer thinner into the tube and let it soak overnight, tried poking a 14 ga. wire through it, all to no avail. Please help. thanks.
Pizza40
| | | | | Joined: Dec 2010 Posts: 291 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 291 | | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Put some heat to it with a torch & poke a wire through it. This is done after it is dissasembled & any gas dried out. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2000 Posts: 5,206 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,206 | We use heat at work to clean out dirty mufflers on weedeaters and such, it turns the crud to dust, then you can just blow it right out.
Joe | | | | | Joined: Dec 2010 Posts: 291 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 291 | you can try some oven cleaner. That seams to eat threw it good. | | |
