2 members (Maybellene, Gazz),
103
Mod | | | Forums66 Topics128,096 Posts1,056,482 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 194 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 194 | I have been told that a 2-ton truck I am wanting to get is a second series. How can I tell? | | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | Check here, lots of pics that will show the differance: http://www.stovebolt.com/gallery.htm My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: Aug 2011 Posts: 194 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 194 | If you look in Gerald Krahn's first series blue 2 ton dump truck, it looks exactly like the one I hope to get, but so does Matt Droege's 2nd series 1955 Chevy 6500. They have the same mirrors, cab, glass, and front end look and shape. But on Clayton Truman's second series Chevy tanker truck, it has the grille that looks like a grid. I also noticed some of the 2nd series have the fender lights on them. How can I tell them apart? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | sometimes the gallery listings get misplaced, the 55 1st series trucks are the Advance-Design 47-54 style, the 55 2nd series are the Task Force 56-59 style, the grills on the different sizes [light/medium vs heavy] are different most years, and the GMC's are different than Chev's .... the 55 2nd to 57 are nearly identical, the 58 and 59 are nearly identical, the main differences are in the hood and fender emblems
Bill | | | | | Joined: Aug 2011 Posts: 194 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 194 | I noticed the hood emblems on some of these heavy chevys are long and skinny, while others short and plump. Which is which? | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Your truck is a '55 2nd series. The difference in the hood emblems is this, the '55 model trucks have the shorter, plump hood emblem, while the '56, & '57 models have the longer, skinny emblems. | | | | | Joined: Aug 2011 Posts: 194 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 194 | [/url]Front end pic Does mine have the 1st series hood on a 2nd series body? It has a really long hood emblem! | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | 1955 Chevy 6400, You have a 1955 Second Series 6400, it looks all original with the correct Hood (same Hood is used on 1956), Hood Embelem and Fender Embelems. Go to the Gallery and look at other 55's and the 56/57's to see the difference. As Spanky said, the 56 and 57 Hood Embelems are the same except they are painter in reverse to each other. The 56 has a Red bowtie and Black surround while 57 has a Black Bowtie with Red surround. Mike B  | | | | | Joined: Aug 2011 Posts: 194 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 194 | Thanks for the help gents! Anyone else have input or ideas? | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | Hey, 1955 6400! My 2nd-series '55 has the short,fat hood-emblem, which,as Mike B mentioned, are the same,except for the opposing paint schemes. Starting in '55,Chevy owners had the choice of two different engine configurations:straight-six-(the short-style hood emblem),or the "long-skinny".style emblem.signifying a V-8-powered vehicle. I hope this helps. Sincerely: [email protected] | | | | | Joined: Aug 2011 Posts: 194 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 194 | The one I hope to get started on next year is an inline 6. Thanks wetwilly5757! Finally a direct, straight forward answer! | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | wetwilly5757, The hood embelems were ALL the same for Second Series 1955 trucks regardless of the engine installed, there was no differenct between 6 and 8 cylinder equiped embelems. The picture of 1955_Chevy_6400's truck shows the correct emblem that was used on ALL 1955 Second Series trucks. The long skinny emblems used on the 56/57 trucks were made with and without a "V", which identified the truck as having a V8 engine. Mike B  | | |
