2 members (3B, 1 invisible),
57
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,074 Posts1,055,911 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | can anybody tell me if the 6 lug wheels from a late model chevy,(suburban,tahoe,etc.)will fit my 6 lug 46 lug pattern? or is there certain years thatwill work?....thanx | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | They will fit the lug pattern, but they won't clear the tierods. Modern wheels are offset in to far. The 15 X 8 inch steel rallys found on 4x4 chevys up to 1989 will work reasonably well. | | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | ok, thanks, now, when I go to the junk yards i'll know what to look for
| | | | | Joined: Aug 2011 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 30 | Not sure if this helps but here is a picture of my 50 with everything stock. I have a set of newer 4x4 rims on there to roll around on. The rims were on it when I got it (from my dad) so I am not sure what they came off of but they seem to work decent for now. By the look of them and the fact they went on sometime in the 90's would make me guess they are pre 89' like bigbadswingdaddy suggested. Maybe you will see a set that looks like this. http://i901.photobucket.com/albums/ac218/Root2812/1950%20Chevy/untitled.jpg
------------------------- 1950 Chevrolet 3100 5 window Original 216ci and SM420 4-speed
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Those are the '73-'87 Truck Rallye, which was also used to '91 on the full size Blazer and 1/2 ton Suburban 4x4.
Bill Burmeister | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | One of the problems I've run into when I go to the junk yards around here is the blank stare when I ask for a certain model and year of wheel. About all they’re familiar with is the bolt pattern and it seems they don't have a clue as to what the offset is or what year they are off of. At one yard that’s been here for 50 years the owner couldn’t even tell me whether the wheels were off of a Chevy, Ford or Chisler.
What would really be helpful would be a good accurate guide or chart with some pictures and dimensions of the different year rims that fit the unmodified AD. With that in hand one could head out to the pile of rims at the junk yard and start pickin' with some confidence.
Any one body out there got enough time and knowledge to come up with a list like that???? DG
Denny G Sandwich, IL
