7 members (Otto Skorzeny, 1955 1 Series, JW51, treegrower, cmayna, Gray_Ghost, 1 invisible), 161 guests, and 2 robots.
Topics128,071
Posts1,055,901
Members48,429
#787127 10/08/2011 4:52 PM
can anybody tell me if the 6 lug wheels from a late model chevy,(suburban,tahoe,etc.)will fit my 6 lug 46 lug pattern? or is there certain years thatwill work?....thanx
hoozat #787162 10/08/2011 9:02 PM
They will fit the lug pattern, but they won't clear the tierods. Modern wheels are offset in to far. The 15 X 8 inch steel rallys found on 4x4 chevys up to 1989 will work reasonably well.
ok, thanks, now, when I go to the junk yards i'll know what to look for
hoozat #787550 10/10/2011 6:27 AM
Not sure if this helps but here is a picture of my 50 with everything stock. I have a set of newer 4x4 rims on there to roll around on. The rims were on it when I got it (from my dad) so I am not sure what they came off of but they seem to work decent for now. By the look of them and the fact they went on sometime in the 90's would make me guess they are pre 89' like bigbadswingdaddy suggested.
Maybe you will see a set that looks like this.
http://i901.photobucket.com/albums/ac218/Root2812/1950%20Chevy/untitled.jpg
1950 Chevrolet 3100 5 window
Original 216ci and SM420 4-speed
Root2812 #788041 10/12/2011 2:07 AM
Those are the '73-'87 Truck Rallye, which was also used to '91 on the full size Blazer and 1/2 ton Suburban 4x4.
Bill Burmeister
LONGBOX55 #788136 10/12/2011 1:03 PM
One of the problems I've run into when I go to the junk yards around here is the blank
stare when I ask for a certain model and year of wheel. About all they’re familiar with is
the bolt pattern and it seems they don't have a clue as to what the offset is or what year
they are off of. At one yard that’s been here for 50 years the owner couldn’t even tell me
whether the wheels were off of a Chevy, Ford or Chisler.
What would really be helpful would be a good accurate guide or chart with some pictures
and dimensions of the different year rims that fit the unmodified AD. With that in hand
one could head out to the pile of rims at the junk yard and start pickin' with some
confidence.
Any one body out there got enough time and knowledge to come up with a list like
that????
DG
Denny G
Sandwich, IL
