3 members (2-Ton, 1955 1 Series, Phak1), 126 guests, and 2 robots.
Topics128,091
Posts1,056,449
Members48,443
Apprentice
Apprentice
I am in the process of swaping chevy stock front brakes to Nissan disk brakes. I understand that to do so I need to remove the shafts as to have them machined to fit nissan´s bearings diameters.
The question is how to get those shafts loose?. Do I need special tools, method ? or the like?
Chevy'51
GMC '54
GMC '56
GMC '59
Lazyduck,,,
I believe this is what you are looking for
http://www.stovebolt.com/techtips/kingpins.htm
Apprentice
Apprentice
Thank you Mechainiac. I have reviewed the tech tip. It is clear enough. It refers to replace something after the removal. I believe the kingpin damaged when extracted. Is there a place to purchase them or drawing to have them made locally?.
Chevy'51
GMC '54
GMC '56
GMC '59
Have you checked out the links pages here on the Stovebolt?
http://www.stovebolt.com/links/parts.htm
