1 members (Otto Skorzeny),
201
Mod | | | Forums66 Topics128,091 Posts1,056,387 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2003 Posts: 26 Apprentice | | Apprentice Joined: Jul 2003 Posts: 26 | I am in the process of swaping chevy stock front brakes to Nissan disk brakes. I understand that to do so I need to remove the shafts as to have them machined to fit nissan´s bearings diameters. The question is how to get those shafts loose?. Do I need special tools, method ? or the like?
Chevy'51 GMC '54 GMC '56 GMC '59
#7871 10/24/2003 11:29 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Lazyduck,,, I believe this is what you are looking for http://www.stovebolt.com/techtips/kingpins.htm
| | | | | Joined: Jul 2003 Posts: 26 Apprentice | | Apprentice Joined: Jul 2003 Posts: 26 | Thank you Mechainiac. I have reviewed the tech tip. It is clear enough. It refers to replace something after the removal. I believe the kingpin damaged when extracted. Is there a place to purchase them or drawing to have them made locally?.
| | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Have you checked out the links pages here on the Stovebolt? - http://www.stovebolt.com/links/parts.htm
