5 members (FAST55, MickeyP, mo2cyl, Gdads51, 66flea), 87 guests, and 1 robot.
Topics128,049
Posts1,055,652
#78702 06/12/2007 1:16 PM
I got the disc kit from Chevy Duty for my AD. I bought hoses for the calipers from a 75 Lemans, and they're too short to fit in the notch in the frme and reach to the caliper. I cut a lenght of wire to the length of the the stock hose, and am in the prcoess of finding one at a FLAPS. Offhand, does anyone have a part number for a hose that will work? Chevy Duty is no help. (I'm asking because I have no provisions to cut and reweld the notch for the hose.)
Thanks as always,
Jason
Your lack of preparation is not my emergency
#78703 06/12/2007 7:12 PM
NAPA's paper catalog lists them by the end fitting type & overall length. In the back of the same book it has all the retaining clips & copper sealing washers by dimension that you may need.
Doug
#78704 06/12/2007 7:31 PM
I got mine from Pure Choice. They have hoses up to 18" in length, perhaps longer.
http://www.performanceplumbing.com/Pure_Choice.shtml
~Jim
#78705 06/12/2007 7:50 PM
Look in the phonebook for a hydraulic shop that makes brake lines. Start calling around and someone will tell you where to go. Up here theres only 1 shop that makes them, as they have to be DOT compliant. They built mine and pressure check them for ya, somthing like 15-25$ a hose.
My 1953 Chevrolet
1947.1 Gallery
#78706 06/12/2007 8:42 PM
Thanks all. I'll probly find a NAPA. I think there's one just up the street...
Jason
