| | | Forums66 Topics128,035 Posts1,055,557 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#78702 06/12/2007 1:16 PM | Joined: Sep 2004 Posts: 168 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2004 Posts: 168 | I got the disc kit from Chevy Duty for my AD. I bought hoses for the calipers from a 75 Lemans, and they're too short to fit in the notch in the frme and reach to the caliper. I cut a lenght of wire to the length of the the stock hose, and am in the prcoess of finding one at a FLAPS. Offhand, does anyone have a part number for a hose that will work? Chevy Duty is no help. (I'm asking because I have no provisions to cut and reweld the notch for the hose.)
Thanks as always,
Jason
Your lack of preparation is not my emergency
#78703 06/12/2007 7:12 PM | Joined: Apr 2005 Posts: 275 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 275 | NAPA's paper catalog lists them by the end fitting type & overall length. In the back of the same book it has all the retaining clips & copper sealing washers by dimension that you may need. Doug | | |
#78705 06/12/2007 7:50 PM | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Look in the phonebook for a hydraulic shop that makes brake lines. Start calling around and someone will tell you where to go. Up here theres only 1 shop that makes them, as they have to be DOT compliant. They built mine and pressure check them for ya, somthing like 15-25$ a hose. | | |
#78706 06/12/2007 8:42 PM | Joined: Sep 2004 Posts: 168 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2004 Posts: 168 | Thanks all. I'll probly find a NAPA. I think there's one just up the street...
Jason
