5 members (Steveoreno, Phak1, kades51, NorCal52Suburban, TUTS 59), 87 guests, and 6 robots.
Topics128,187
Posts1,057,211
Members48,465
#78676 06/11/2007 2:29 PM
Not to due with the older trucks. But my 454 1985 1T is just loosing oil. It has a major powersteering leak (which works good on preservation) so actual location of oil leak is kind of hard.
I pulled off the valve covers to see if there was oil puddling up in there. No, small drip in rear drivers side cover. Oil pan has a small drip as well. Oil filter is clean, no drips. Other then that. I cannot locate a actual "LEAK" to match the loss of oil.
Truck blows black smoke for a breif second when started cold OR hot. We ran it for about 10 minutes, off about 30 and when we restarted it, was black smoke. But not under a load. (or at least that I can tell going down road)
Tail pipe looks like a fireplace chimmney. It is smutted with black. Not wet, like powder.
Truck has been known to use oil (after all its a 454) but it was sitting since last use (roughly 1 month) and it was bone dry. We only had 3 qts and put it in, filled it up to about 1/2 on the dip stick. We filled it up at the nearest store that carried oil (roughly 20 miles away) We drove it roughly 40 miles (under a load) And back home. Total trip, about 60 miles. Truck was 1 1/2 qt's low. So it is using/burning oil.
Got any ideas? :confused:
Chey
LOST1953
My favorite color is CHROME
The ugliest trucks are driven by the prettiest girls wink
I dont suffer from insanity, I enjoy it!
O Lord, WHY did I buy another "Thing"? (again??)
1953 Chevy 3800 1-ton Gallery
More photos at MSN
#78677 06/11/2007 3:29 PM
black smoke is carburator.........pressure wash engine to help find leak.....
#78678 06/11/2007 4:37 PM
Lost1953
Try a new PCV valve sometimes if they get stuck they will allow the engine to draw the oil out through the PCV system.
DS
#78679 06/11/2007 4:43 PM
see if it is leaking out and burning away on the exhaust pipes... have someone follow you and watch for smoke as you do various things.. ie.. up/down shifting, putting a load on it..
Another quality post.
Real Trucks Rattle
#78680 06/11/2007 4:49 PM
PCV?? I dont mean to sound dumb (I am) but what is a PCV?
I followed my Hubby that last time (well, time b4 last) and I never saw it blow smoke...
:confused:
Also, truck never runs hot, always maintains its temp in 100' weather of 30' weather.
Chey
LOST1953
More photos at MSN
#78681 06/11/2007 5:35 PM
Could be the main seals, too. Or possibly the dulge plug, but that's unlikely.
The PCV is the Positive Crankcase Ventilation valve. It meters the amount of fresh air that goes through the crankcase to ventillate the blowby.
Bill Burmeister
#78682 06/11/2007 5:53 PM
PS: No oil puddles, other then the small drips
Chey
LOST1953
More photos at MSN
#78683 06/12/2007 1:33 PM
i would replace the PCV valve ...and go from there ..NO BLUE SMOKE AT SHIFTING ???
1952 Chevy Shortbed
Photos in Photobucket
