| | | Forums66 Topics128,197 Posts1,057,258 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#78676 06/11/2007 2:29 PM | Joined: Apr 2007 Posts: 146 Shop Shark | | Shop Shark Joined: Apr 2007 Posts: 146 | Not to due with the older trucks. But my 454 1985 1T is just loosing oil. It has a major powersteering leak (which works good on preservation) so actual location of oil leak is kind of hard. I pulled off the valve covers to see if there was oil puddling up in there. No, small drip in rear drivers side cover. Oil pan has a small drip as well. Oil filter is clean, no drips. Other then that. I cannot locate a actual "LEAK" to match the loss of oil. Truck blows black smoke for a breif second when started cold OR hot. We ran it for about 10 minutes, off about 30 and when we restarted it, was black smoke. But not under a load. (or at least that I can tell going down road) Tail pipe looks like a fireplace chimmney. It is smutted with black. Not wet, like powder. Truck has been known to use oil (after all its a 454) but it was sitting since last use (roughly 1 month) and it was bone dry. We only had 3 qts and put it in, filled it up to about 1/2 on the dip stick. We filled it up at the nearest store that carried oil (roughly 20 miles away) We drove it roughly 40 miles (under a load) And back home. Total trip, about 60 miles. Truck was 1 1/2 qt's low. So it is using/burning oil. Got any ideas? :confused:
Chey LOST1953 My favorite color is CHROME The ugliest trucks are driven by the prettiest girls  I dont suffer from insanity, I enjoy it! O Lord, WHY did I buy another "Thing"? (again??) ---- 1953 Chevy 3800 1-ton Gallery More photos at MSN ----
#78677 06/11/2007 3:29 PM | Joined: Feb 2006 Posts: 112 Member | | Member Joined: Feb 2006 Posts: 112 | black smoke is carburator.........pressure wash engine to help find leak..... | | |
#78678 06/11/2007 4:37 PM | Joined: Jun 2006 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 85 | Lost1953 Try a new PCV valve sometimes if they get stuck they will allow the engine to draw the oil out through the PCV system. DS | | |
#78679 06/11/2007 4:43 PM | Joined: Dec 2002 Posts: 3,445 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,445 | see if it is leaking out and burning away on the exhaust pipes... have someone follow you and watch for smoke as you do various things.. ie.. up/down shifting, putting a load on it..
#78680 06/11/2007 4:49 PM | Joined: Apr 2007 Posts: 146 Shop Shark | | Shop Shark Joined: Apr 2007 Posts: 146 | PCV?? I dont mean to sound dumb (I am) but what is a PCV?
I followed my Hubby that last time (well, time b4 last) and I never saw it blow smoke... :confused:
Also, truck never runs hot, always maintains its temp in 100' weather of 30' weather.
#78681 06/11/2007 5:35 PM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Could be the main seals, too. Or possibly the dulge plug, but that's unlikely. The PCV is the Positive Crankcase Ventilation valve. It meters the amount of fresh air that goes through the crankcase to ventillate the blowby.
Bill Burmeister | | |
#78682 06/11/2007 5:53 PM | Joined: Apr 2007 Posts: 146 Shop Shark | | Shop Shark Joined: Apr 2007 Posts: 146 | PS: No oil puddles, other then the small drips
#78683 06/12/2007 1:33 PM | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | i would replace the PCV valve ...and go from there ..NO BLUE SMOKE AT SHIFTING ??? | | |
