3 members (Otto Skorzeny, Materman, 55shaker), 61 guests, and 1 robot.
Topics128,079
Posts1,055,941
Members48,430
#786032 10/04/2011 4:26 PM
Hi all. I have a 1953 GMC 3 ton and we are replacing all the glass. Any advice or things I should look out for inparticular? Thanks.
1st Gen. Dodge Cummins 4x4 OVRTRQD Buick GNX #276
"If it died... we can fix it" | "If your not outraged, you're not paying attention." | "Do you know a large group of baboons is called a Congress? That explains a lot." ~author unwn
Do you have the original glass?
If so i would strongly recommend you find a local glass shop who can use the originals as templates.
Why? Because i've noticed some aftermarket kits are 'marginal' to say the least.(Speaking from experience)
The front windshields I copied from a friends set were a lousy fit.
I assume you'll be replacing rubber seals too.
Steele Rubber seem to be the ones most favoured around here.
Not the cheapest but by all acccounts the best.
More pix on Flickr.
The box of glass came in today - only had time to make sure that none of it was broken. Marginal eh? At least I'll know what I am getting into. I do have the originals - 3 broken and the rest badly bubbled. Otherwise I guess we wouldn't have replaced them. I ordered the whole weatherstrip kit (Golden State Parts). Too late to go back now. Well let's hope I get lucky and everything fits. Thanks for the info. I'll let you know. smile
I had a time with my side glass but it was due to a lot of problems.....the "old" glass must have not been original and cut to worn out channels.
I did check some originals to a set of new ones back a year or so ago and there was very little difference. Not enough to cause a problem anyway....but that was back them!! I've read many testimonials here that the window channels are as big of pain, even somewhat more so than the glass itself.
But we have lemons and peaches in all of the stuff at times.
Good luck. let us know how you come out.
I wasn't trying to rain on your parade OVRTRQD.
I was just relating my personal experiences,I'm sure they're not all bad.
Like Alvin said,your 'original' glass might not all be as it was when it left the factory.
A lot can happen over nearly 60 years!
Check your new glass against what came out your truck and it'll give you a better idea of what you've got to work with.
Good luck and as Alvin already mentioned,let us know how things go.
More pix on Flickr.
Appreciate all the input - you're not raining on my parade. I always look forward to a little challenge. It would be boring otherwise, right?
All the glass looks good so far. We 'eyeballed' them up to the old glass and they all seem the same. I do have a question on the wing windows though. There is a couple washers and a spring and nut that go on the bottom of the wing windows - seems we all forgot what order they go back on and none of the reference material I have shows a really clear picture. Any ideas? Thanks.
Ovrtrod, I don't have a good picture but I do have it written down in the shop. PM me so I'll remember it and I'll post it here for anyone else that needs it.
I do remember there is a couple leather wahers and one of them goes "inside the little box".....I'll check tomorrow afternoon if I can remember!!
Hey, I think I also have an extra set of the spring deal. I could maybe take it apart and take a pic.
I used this image from Squeezes catalog to reset mine
Vent spring 2
Vent Spring assembly
Give me ambiguity
or give me something else
Had a feeling those suckers were wrong. Already riveted it back together! Another challenge ahead - you all are the gurus. smile
