5 members (CuzzFuzz, greenie-reddy, TexasA&M48Truck, Peggy M, 1955 1 Series), 48 guests, and 7 robots.
Topics128,012
Posts1,055,320
Members48,419
#773814 08/22/2011 4:35 AM
I am about to change all of the fluids in my new truck and I was wondering. What sort of fluids do you use for your trucks? Oil? Transmission? Breaks? Thanks for your help.
dw_moto #773818 08/22/2011 4:41 AM
dw,
i have a 66 chevy c/60 with a 366 cid big block i use:
oil : 10w30 or 10w40
manual tranny: 80w90 gear oil
brakes: dot3 brake fluid
hope that helps.
1966 Chevy C/60 Wrecker
Story in the Gallery
Pictures on Flickr
It don't rust if you run it hard enough
Alex an Mader #773823 08/22/2011 4:49 AM
That's what I need to know. Thanks
dw_moto #785977 10/04/2011 7:33 AM
I have a 1949. I run 90w in trans and rear, 30W Non-Detergent in engine, and DOT 3 in brakes. Never run anything less than 15W-40 in my '69 or '90 trucks as this was advise from my local GM mechanic so I feel 30W is fine. Also running lead additive in fuel. Just my 2 cents
1949 1.5 Ton 4400, 1969 c10, 1989 c1500, 1990 K2500, 2010 C1500 Crew
dw_moto #786000 10/04/2011 1:20 PM
Save your money with the lead additive. Under normal use the fuel today will be just fine. Don't make the mistake of putting to thick of motor oil in the engine, with the splash oiling thinner is better than thicker.
don stocker #786145 10/04/2011 11:46 PM
What year truck?
What engine (and year)?
What transmission/year?
tclederman #786215 10/05/2011 2:58 AM
Sorry, forgot to add that the engine in my 1949 is now a high pressure 235 out of a mid 50's truck.
