Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 49 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#7858 03/20/2003 4:23 PM
Hey guys,
I'm changing my vacuum advance and need to know the correct timing. I looked up several topics and one said 4 degrees ATDC and that didn't sound right. What is the timing on a 54 235 chevy. Thanks, Pilot
#7859 03/20/2003 11:49 PM
Line it up with the ball on the flywheel, it's 5* btdc if I remember right.
Paint & Body Shop moderator
#7860 03/21/2003 3:49 PM
You can give it 5 to 10 degrees BTDC. The old-timers say that if you can 'bump' the key and she fires, the timing is right.
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#7861 03/21/2003 9:51 PM
V
V Offline
To directly answer your question , the is a small window just above the starter , it has a tiny pointer hanging down and when the engine is idling , you'll see a ball bearing pressed into a hole on the flywheel , line it up with the pointer
and you're good to go . you might consider removing the flywheel splash pan and marking the ball bearing with a circle of white paint as it is hard to see , use the wifey-poo's nail polish ,
it'll last forever .
There should be _no_ vacuum at the advance hose when the engine is at idle ! .
-Nate
There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
