4 members (klhansen, 32Fordpuchoptop, FAST55, walter74), 95 guests, and 2 robots.
Topics128,120
Posts1,056,319
Members48,439
#785346 10/02/2011 12:18 AM
Putting my 52 1/2 ton back together and the flywheel has some minor rust. One section about 2" wide is just slightly ruff even after sanding. At what point should I have it turned at a machine shop? Will it make a big difference given the power of the 235 in my truck?
3B Offline
Hy ADspudnut, I don't know about it making a difference given the power, but if the surface is not flat and consistant, it will definately make a difference to the life of the clutch disc, and possibly the smooth engagement of the clutch. Just the fact that you're concerned about the surface says you should have it surfaced.
Have it professionally resurfaced!
or,
it WILL slip in short order ,,, ask me how I know this
mike\
ok..I'm convinced...off to the machine shop
