| | | Forums66 Topics128,162 Posts1,056,938 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | I know this has been talked about, but here is how it can be done. Restorodstogo.com Nice work, doesn't look as hard as I thought it would be. It's nice when you know what you are doing!  | | | | | Joined: Jan 2007 Posts: 219 'Bolter | | 'Bolter Joined: Jan 2007 Posts: 219 | I can appreciate the work after patching together a truck, all you need is patience and a little know how and when you don't know how you ask. Don't forget a little filler goes a long way in the end so the welding dose not have to be perfect, just needs to be solid.
layback
| | | | | Joined: Apr 2010 Posts: 245 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 245 | Pretty Cool! That'll get 'em talkin'. | | | | | Joined: Sep 2011 Posts: 205 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 205 | I have a clam shell upper door on mine too..and lower tailgate..I noticed a rusty spring on right side of upper door frame..how does that come out..(carefully)..have to go in there and get it out and? I think I have the lift lock arm too. | | | | | Joined: Nov 2010 Posts: 22 New Guy | | New Guy Joined: Nov 2010 Posts: 22 | WOW!! Just WOW!! That is SO cool. We are getting started on the resurrection of our much beloved '49 Burb. The Barn-door setup is what we wanted for the ease of getting up to the floor, so we were thinking about swapping the clamshell configuration for barn doors, but this is much better. Got to show it to the resto shop where the Punkin is currently waiting before the trip to the shop that will do the mechanical fabrication. | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Stryter, if you like that one, how about this one ? Another view. Cletis took these at the reunion. | | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | I also saw this one at the reunion. Very nice job. He also had removed the sliding side windows and replaced them with solid stationary glass and added air conditioning among other improvements. Very cool cruiser.
Weeds | | |
