0 members (), 106 guests, and 0 robots.
Topics128,101
Posts1,056,181
Members48,436
#785220 10/01/2011 6:45 AM
Way better than I ever thought it would be.The wood is in good condition cuase it was stored inside garage ..except under the cab some rotted there. Any special things I need to know about removing the body from the frame? Will have to be done to replace some wood underneath the cab. And Body guy said he'll make a steel JIG to move body around for easy working...will have to keep wiring harness in tack to replace it. Anything else I should be aware of for removel of body? thanks.
1936 Chevy Suburban Carryall
1941 Chevy Woodie with Cantrell body
1936 Low Cab Chevy Pickup
1941 Spec Deluxe Chevy Coupe.
1953 Pontiac Catalina hardtop
More pix on Flickr
Bondo Artiste
Bondo Artiste
Pictured, pictures, pictures, we all love pictures here. Don't know much about the earlier suburbans hang tight I'm sure someone will chime in for you soon. Congrats on your new purchase and I'm looking forward to updates and photos.
~ Phillip
Leo Offline
Moderator
Moderator
Good that it's better than expected, usually it's the other way around. Be sure to label everything you take off, especially the small stuff or you will have a pile left over with no clue what it is.
Leo #785259 10/01/2011 3:35 PM
Yeah, you can't have to many ziplock bags and sharpie markers in the shop!
Can't wait to see pictures.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
I can see the smile from S.C. Glad its in better shape. Man, that is going to be THE ride in town before long! I'm jealous!
Way to go, Bruce!! I'm so glad that it has arrived safe and sound! Ditto, on the pictures, pictures, pictures. smile
I'm excited for you. I passed a '39ish Panel today with a great big sign on it "NOT for sale". LOL
You will have everybody jealous, probably already do. grin
Last edited by Husker; 10/02/2011 8:25 PM. Reason: correction, it was a panel not a 'burb
Well thanks for the well wishes..cleaned it all up today took out the old beat springs..saved and taged..found a few little goodies down amoung the mice nests and acorns shells...(Found a part of a sunvisor, with chrom end to go on pass side..gotta find another one.. poured some marvel M Oil into those old spark plug holes. Took a few pics...will post them soon. Anyone with Suburban spare part?(oh yeah right ) ha! Tailgate and upper window clam door will take some rebuilding with wood...but it;s pretty tight...B
More pix on Flickr
Removing the body is like moving a house - you will need to support it well under all the body mounts or you risk tearing it apart at the cowl and windshield pillar attachment points at the roof.
There are a lot of joints in the wood that were glued and often the glue is long failed and the joints are held together with a single bolt that allows quite a bit of rotation / flex.
Take it slow and easy - and if that motor doesn't free up - I have it's replacement sitting right here ready to go!
Life's short - don't waste it.
Would that engine be a 207? When did the change to the 216 happen?
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1926 Model TT Truck
I believe they went to the 216 in 1937 but someone else can verify.
Alvin is correct about the 216 being introduced in 1937. I think that all three of the first generation stove bolt engines might have been available in 1936: 181, 194, and 207 .
Have you gone to the GM Heritage site for Vehicle Information Kits? The 207 ci (206.8) engine is shown in the 1936 specifications manual.
Where in Idaho are you? It would be cool to see it.
