0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#78455 06/05/2007 8:09 PM | Joined: Jun 2007 Posts: 14 Junior Member | | Junior Member Joined: Jun 2007 Posts: 14 | I need an oil filter setup on my '54 3800. Evidently, it was never equipped with one. Thx!
Kurt@KKF
Kurt@KKF
1954 Chevy 3800 1-Ton Flatbed
#78456 06/05/2007 10:11 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Get one from a salvage with u-bolts & get a hose kit from one of the specialty suppliers. They are easy to put on. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#78457 06/05/2007 11:23 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Or if you're not concerned about keeping the vintage look you can make your own.
#78458 06/05/2007 11:27 PM | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Lots of info available on the bypass filter in the search section. I discovered that plugging the 1/8 NPT supply and return ports, gave me an additional 5-7 psi of oil pressure. Being that the bypass filter only filters a limited amount of oil at one time, I felt that the additional oil pressure to the bearings was a fair trade-off.
Once you establish your operating oil pressure without the bypass filter, you can decide whether you want to sacrifice the additional oil pressure.
Secondly, the filter can/filter need to be filled with oil after changing out the old filter, to avoid pressure bleeding off from the system while the filter and can fill, and come up to pressure. This period of time, without full oil pressure to the bearings would have a negative effect on bearing life. Changing my oil a little more frequently seems easier than changing out oil-starved bearings. Maybe some others will add their thoughts. Hope this helps.
Dave | | |
#78459 06/06/2007 12:56 PM | Joined: Jun 2007 Posts: 14 Junior Member | | Junior Member Joined: Jun 2007 Posts: 14 | Thx! While I want to keep the truck original (it's amazingly complete, but 12V) the oil pressure is an issue, since I'm going to rebuild the engine. This will also allow me to D&T for lines/mounts. I own a machine shop. I just don't know where they tapped the gallery. I found 3 D&T's hole on the left/front of the block, but I don't know if this is for the canister mount. I looked for the Tips and Tricks section, but didn't find it.
Kurt@KKF
#78460 06/06/2007 5:36 PM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The supply line for the filter is the same one used for the oil pressure guage, they just simply T-d off from it. The return line goes to a threaded hole just about in line with cylinder #3, about an inch above the oil pan rail. This just simply dumps back into the pan. Personally, I'd prefer to run with a filter. I feel that even a little filtering is better than none at all.
Bill Burmeister | | |
#78461 06/06/2007 7:54 PM | Joined: Jun 2007 Posts: 14 Junior Member | | Junior Member Joined: Jun 2007 Posts: 14 | Thx! Now I'm getting somewhere!
Kurt@KKF
#78462 06/06/2007 8:44 PM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | |
#78463 06/06/2007 8:59 PM | Joined: Jun 2007 Posts: 14 Junior Member | | Junior Member Joined: Jun 2007 Posts: 14 | 'D&T' is Drill & Tap. Thx! In that pic of the locations, what are the 3 tapped holes ahead of the 'from filter outlet? Are these holes for mounting the filter canister? It looks like, from the diagram, that the filter canister mounts with U-bolts to the intake manifold?
Kurt@KKF
#78464 06/06/2007 9:11 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Originally posted by KurtsKustom: 'D&T' is Drill & Tap. Thx! In that pic of the locations, what are the 3 tapped holes ahead of the 'from filter outlet? Are these holes for mounting the filter canister? It looks like, from the diagram, that the filter canister mounts with U-bolts to the intake manifold? The canister hangs from the intake manifold. I don't have a 235 but from their location I'd guess they have something to do with mounting the generator. I'm sure I'll be corrected if I'm wrong.
#78465 06/06/2007 9:39 PM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I do beleive that the pic is of a late ('58-'62) block, and those are for the side mounts used after '58, right?
#78466 06/06/2007 10:38 PM | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Hey Kurt,
Click on the link below of my webshots, then on "Tips and Tricks". On about page 5 as I tried several mount locations and hose configurations. If you're planning on running headers you'll need to consider the heat problem....I finally found a way around that situation. It would work for both the stock bypass filter or also the full-flow. It's not the only way...just the way that worked best for me.
Also...saw your "central Florida" location, was curious if you were in or near my neck of the woods. Lake Wales.
Dave | | |
#78467 06/06/2007 10:49 PM | Joined: Jun 2007 Posts: 14 Junior Member | | Junior Member Joined: Jun 2007 Posts: 14 | Thx! I'm in Bushnell/Sumter Co. My website: KKF
Kurt@KKF
#78468 06/07/2007 2:14 AM | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | Tim Thanks for the links to the Pics. High Kudoes as Always, Regards, | | |
#78469 06/07/2007 2:18 AM | Joined: Feb 2002 Posts: 61 Member | | Member Joined: Feb 2002 Posts: 61 | Originally posted by KurtsKustom: Thx! I'm in Bushnell/Sumter Co. My website: KKF Ah.... a 'familiar' face..... I thought it was you.....
1948 Dodge 2 ton 1950 GMC 1 1/2 ton 1952 GMC 3/4 ton
#78470 06/07/2007 4:30 AM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | In that pic of the locations, what are the 3 tapped holes ahead of the 'from filter outlet? Are these holes for mounting the filter canister? It looks like, from the diagram, that the filter canister mounts with U-bolts to the intake manifold? - I do not know what the holes are for - I do not think they have been tapped. As stated above, they seem to be located where the passenger motor mounts would be located. - I will double check the block casting number tomorrow to confirm the date of the engine. It might not be original. - If mounted closer to the front of the intake manifold, I do not think that the canister would get in the way of the generator. In earlier years, it might have gotten in the way of the horn (ask Denny). picture of a \'55-\'62 filter canister mounted on a \'54 235 Tim | | |
#78471 06/07/2007 12:38 PM | Joined: Jun 2007 Posts: 14 Junior Member | | Junior Member Joined: Jun 2007 Posts: 14 | Originally posted by Kaliburz: Originally posted by KurtsKustom: [b] Thx! I'm in Bushnell/Sumter Co. My website: KKF Ah.... a 'familiar' face.....
I thought it was you..... [/b]I can't go ANYWHERE anymore w/o being recognized! Check the pic in my profile. No, there's not a gun in the picture...
Kurt@KKF
#78472 06/07/2007 2:40 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | That's a clean engine compartment Tim. Much cleaner than mine.
#78473 06/08/2007 1:54 AM | Joined: Feb 2002 Posts: 61 Member | | Member Joined: Feb 2002 Posts: 61 | Originally posted by KurtsKustom: Originally posted by Kaliburz: [b] Originally posted by KurtsKustom: [b] Thx! I'm in Bushnell/Sumter Co. My website: KKF Ah.... a 'familiar' face..... I thought it was you..... [/b] I can't go ANYWHERE anymore w/o being recognized! Check the pic in my profile. No, there's not a gun in the picture... [/b]:confused:
#78474 06/08/2007 3:59 AM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I do beleive that the pic is of a late ('58-'62) block, and those are for the side mounts used after '58, right? The picture of the block that I posted above, showing the holes for oil lines, is a 1954 235 truck block. The three holes in a triangle-pattern, are tapped. This block casting must have been shared with the passenger car (non-hydraulic lifter 235). Powerglide equipped blocks (hydraulic lifters) would most likely have had a different casting (they do have a different casting number). I have two other 1954 235s and they also have three holes in a triangular pattern on both sides of the block. Tim | | |
#78475 06/08/2007 4:09 AM | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | The cheapest place to find a canster type oil filter canster is at a tractor dealer/tractor repair. Ford N tractors (9N 2N & 8N) use the canster and it won't break the budget buying one.
~Jim
#78477 06/08/2007 5:55 PM | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Just took the tour through the Suburban Tim, very nice. I see what you meant about that Blue being a little darker than my 1950 Mariner Blue. Looks to have a little more red in it also. Denny Graham Sandwich, IL
Denny G Sandwich, IL
#78478 06/10/2007 9:45 PM | Joined: Jun 2007 Posts: 14 Junior Member | | Junior Member Joined: Jun 2007 Posts: 14 | A dearest friend of mine from HS had a '54 Burban. Untouched and running. We were all hippies (EARLY '70's) back then and this truck went to Colorado from IL and all points in between. Every state got a sticker on the left rear quarter glass. We were young and so tight. Memories...
Kurt@KKF
#78479 06/29/2007 8:33 PM | Joined: Jun 2007 Posts: 14 Junior Member | | Junior Member Joined: Jun 2007 Posts: 14 | Originally posted by tclederman: In that pic of the locations, what are the 3 tapped holes ahead of the 'from filter outlet? Are these holes for mounting the filter canister? It looks like, from the diagram, that the filter canister mounts with U-bolts to the intake manifold? - I do not know what the holes are for - I do not think they have been tapped. As stated above, they seem to be located where the passenger motor mounts would be located.
picture of a \'56-\'62 filter canister mounted on a \'54(?) 235
Tim OK, got my oil filter canister. Looks identical to your setup. After a trip through the parts washer, it went to the blast cabinet and on to paint. In your pic, I assume those are the correct colors (this body was orange and had a black(?) top). As nice as your engine bay is, I assume those colors are correct. This body measures @4 1/2" inside. Does this canister use a 4" diameter filter, then? Thx!
Kurt@KKF
#78481 06/29/2007 9:44 PM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Kurt.
My oil filter is not a 1954 filter. Since it is a '55-'62 AC filter, I painted it the AC colors for those years. Your orange and black combination is, as stated by Bill, correct for a Fram.
The Fram filter has a different shaped bottom than the AC filter. I think there are "pinches" in the conical bottom of the Fram filter.
Tim | | |
#78482 06/29/2007 9:48 PM | Joined: Jun 2007 Posts: 14 Junior Member | | Junior Member Joined: Jun 2007 Posts: 14 | THAT's it. Any difference between the two, do they accept the same filter element? Now I'm torn. I already have the top painted (orange), and picked up a can of Duplicolor GM blue for the body at Discount (Advance) Auto Parts. I mentioned the element, and he ran it through the computer, and ordered an element that will be in tomorrow morning. I'm carrying my stripped canister body to them to check to see if it's the right one. Thx!
Kurt@KKF
#78483 06/29/2007 9:53 PM | Joined: Jun 2007 Posts: 14 Junior Member | | Junior Member Joined: Jun 2007 Posts: 14 | Originally posted by tclederman: Kurt.
Tim Yes, my canister bottom has the indents in the pressing. I'm re-doing it to Fram colors. The filter element he showed me on the computer looks to be a Fram (orange). I'll check in the morning. Still, should it be 4" in diameter? Thx!
Kurt@KKF
#78484 07/01/2007 1:37 AM | Joined: Jan 2007 Posts: 50 Member | | Member Joined: Jan 2007 Posts: 50 | The tee that feeds the filter should have a small passage so you don't "dump" your oil pressure into the oil pan. I don't know the size ,maybe about a 32'nd. Best bet would be an original tee.
restoring a 1946 coe wrecker.
#78485 07/03/2007 2:18 PM | Joined: Jun 2007 Posts: 14 Junior Member | | Junior Member Joined: Jun 2007 Posts: 14 |
Kurt@KKF
