7 members (Donf, Gdads51, 55shaker, TUTS 59, Forty9, Donsz, Gray_Ghost),
126
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,056 Posts1,055,799 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#78437 06/05/2007 4:13 AM | Joined: Nov 2006 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 63 | Hey guys, when taking these 2 piece driveshafts to take the front (long) shaft off do I have the drop the hanger bearing carrier from the frame or does it pull out from the hanger bearing?? I wanna be sure how to do this before I try tuggin at things..... Thanks! (P.S...I do want to replace the hanger bearing,...how do I pull the shaft out of the carrier if i need to?)
Thanks,as always -Danny
1960 C-10 Stepside,Longbox 235,4spd 3.90 diff.
#78438 06/05/2007 1:28 PM | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Yes,
1. Mark the driveshaft so it goes together the same way it came off because it is balanced (or should be). I usually mark it on the knuckles with a punch, or chalk works. Just don't rub it off. Take out the hanger bearing bolts. 2. remove the bearings from the rear end. 3. Tape up the bearings on the rear knuckle so they don't fall off (unless you ar replacing them). 4. The rear shaft will pull off the center near the hanger now, or you can pull the whole thing out of the tranny.
Oil will come out of the tranny so get a catch pan. Also a good time to replace the rear tranny seal and the driveshaft knuckles. Check the tranny and rear end oil levels when reassembled. | | |
#78439 06/05/2007 10:22 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I believe there is a bolt holding them together on that model. You have to put a 3/4 open end wrench in front of the center u-joint & unbolt it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#78440 06/06/2007 12:44 AM | Joined: Nov 2006 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 63 | So then I wouldn't have to pull the carrier from the frame? I guess though it would be easier to replace the hanger bearing if I just took the darn carrier off too. Nuts! Those old bolts are r...u...s...t...e...d...!!! plus it's lovely when rusty dirt covers your goggles and face too!
#78441 06/06/2007 7:45 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Those bolts can be hard to get out but the threaded holes are in the bearing so you will get new ones. Once you take it loose the whole assembly will come out. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#78442 06/15/2007 1:12 AM | Joined: Nov 2006 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 63 | Ok So I pulled The carrier and hanger bearing assembly off the truck Now my question is... How do I get the old bearing off the driveshaft? I don't see any bolts so do I take a hammer to it? When I look at my new bearing assembly I got from napa it looks like it just slides onto the spline side of the shaft. (On one side of the hanger bearing is splines on the other is the dust cover and large shaft.) HELP!
#78443 06/15/2007 10:09 PM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | It is a press fit so you'll need to take it to a machine shop if you don't have a gear puller or press. It should only be snug on the midship stub shaft. | | |
