6 members (Gray_Ghost, 78buckshot, 2-Ton, Phak1, TUTS 59, Southerntruck), 75 guests, and 4 robots.
Topics128,151
Posts1,057,001
Members48,460
I have acquired a saginaw 3 spd overdrive transmission...I don't know what it came from. ( A chevy I would imagine) I don't think it really matters.I intend to dissasemble it to see if it is alright internally. My question???/ Has anyone done this swap or should I not even consider it? I realize these aren't the strongest transmissions but I don't intend to do any real heavy hauling with my 3/4 ton anyhow. Just looking for a little better milage. Thx for any help or info anyone can provide. Chris
Have a read through this thread? Do you have a 4 bolt side cover or a seven bolt? There were two different versions for this tranny. Actually they are pretty tough transmissions. The only thing that is getting a bit hard to find is the electric solenoid and governor switch for them. I have the seven bolt later tranny with synchro first and think it was my best addition to my GMC with 305E V6.
Regards,
Steve
New Orleans
https://www.stovebolt.com/ubbthread...Main=103573&Number=712648#Post712648
Thx for the thread info....it is much appreciated. Chris
I wouldn't be concerned about the strength, the main transmission is the same as the base transmisson used in the 3/4 tons. It also saw use behind the FI 283s, 327s, and Big Blocks.
Bill Burmeister
Thx Bill...I appreciate any and all info. Chris
