3 members (dt235sd, 1955 1 Series, 1 invisible),
352
Mod | | | Forums66 Topics128,154 Posts1,057,015 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 7 New Guy | | New Guy Joined: Aug 2011 Posts: 7 | I have acquired a saginaw 3 spd overdrive transmission...I don't know what it came from. ( A chevy I would imagine) I don't think it really matters.I intend to dissasemble it to see if it is alright internally. My question???/ Has anyone done this swap or should I not even consider it? I realize these aren't the strongest transmissions but I don't intend to do any real heavy hauling with my 3/4 ton anyhow. Just looking for a little better milage. Thx for any help or info anyone can provide. Chris | | | | | Joined: Jan 2007 Posts: 93 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 93 | Have a read through this thread? Do you have a 4 bolt side cover or a seven bolt? There were two different versions for this tranny. Actually they are pretty tough transmissions. The only thing that is getting a bit hard to find is the electric solenoid and governor switch for them. I have the seven bolt later tranny with synchro first and think it was my best addition to my GMC with 305E V6. Regards, Steve New Orleans https://www.stovebolt.com/ubbthread...Main=103573&Number=712648#Post712648 | | | | | Joined: Aug 2011 Posts: 7 New Guy | | New Guy Joined: Aug 2011 Posts: 7 | Thx for the thread info....it is much appreciated. Chris | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I wouldn't be concerned about the strength, the main transmission is the same as the base transmisson used in the 3/4 tons. It also saw use behind the FI 283s, 327s, and Big Blocks.
Bill Burmeister | | | | | Joined: Aug 2011 Posts: 7 New Guy | | New Guy Joined: Aug 2011 Posts: 7 | Thx Bill...I appreciate any and all info. Chris | | |
