0 members (),
102
Mod | | | Forums66 Topics128,186 Posts1,057,319 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 291 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 291 | I know sway bar questions have been asked but cant find it in the search.
Is there any sway bar off a differant mae or model I can look for to fab into the front stock suspension of a 59 3100. I found the info on putting a IROC-Z sway bar on the back. But I can not find anything on the front.
I know I can get a new sway bar for the front. But Im cheap so im looking for options.
Thanks all | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | the 55-59 panels and burbs had a factory sway bar, might be able to find one and it'll bolt right up, they use the front spring mount for the ends and a pair of brackets for the body of the bar
Bill | | | | | Joined: Dec 2010 Posts: 291 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 291 | Dang, well Ill have to take a look back in wyoming. I have yet to find a old truck at a junk yard here in california. Thanks for the input. | | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | Grandpa don't limit it to trucks since some fab will be needed anyway. Measure or estimate width and look at the muscle cars. Some had a 1" sway bar which should be stout enough for your 59.
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Grandpa...call ESPO Springs N Things (800-903-9019) and check the web @ www.espo.com. They have springs, shackles, bushings, U bolts, front end kits, etc. and I'm pretty sure that is where I got a sway bar for my 57' BelAir. | | | | | Joined: Dec 2010 Posts: 291 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 291 | Well ill look around and see if anything fits. If so ill share the info. If not I guess Ill get a new sway bar. Thanks for all of your help. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | The new after market ones area heck of a lot better than the stock ones Mine are 1 1/2 inch dia and cost about $150 each from Brothers. | | |
