3 members (JW51, mo2cyl, 1 invisible),
223
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,083 Posts1,055,967 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 143 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 143 | I've reworked the doors on my '50 3100. I can't get the passenger door to lock. I can lock the door from the inside and no matter what I can open the door with the outside handle. I also installed a new lock and as I've read here the new locks are junk. No way I can get the new lock working. I would be happy if I were able to get the inside lock working. I've had this thing apart several times and no matter what, when the door is locked from the inside the outside handle will turn, unlock and open the door. Has anyone else dealt this issue? Thanks.
It never costs more to ask and it never costs more to think big.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Will this help you. You can page forward or backward. http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0113.htmIts been a while since I messed with your type. | | | | | Joined: Aug 2004 Posts: 143 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 143 | Achipmunk, thanks for the info. I went thru the shop manual info but can't seem to find the problem. With the door panel off I can lock the door from the inside. I then open the door from the outside and can see the lock mechanism toggle forward and push the door lock remote bar out of it's locked position. I've tried adjusting and repositioning but get he same result. I checked for the same type of action on the drivers side. The drivers side lock mechanism does not toggle forward far enough to cause this problem on the drivers side when opened from the outside. Drivers door locks great. Tomorrow I will try to get a pic.
