3 members (Gdads51, 1955 1 Series, cmayna), 113 guests, and 2 robots.
Topics128,193
Posts1,057,249
Members48,466
I know sway bar questions have been asked but cant find it in the search.
Is there any sway bar off a differant mae or model I can look for to fab into the front stock suspension of a 59 3100. I found the info on putting a IROC-Z sway bar on the back. But I can not find anything on the front.
I know I can get a new sway bar for the front. But Im cheap so im looking for options.
Thanks all
1959 Chevy Apache 3100/ 283 TBI / 4L60E
My YouTube:
https://www.youtube.com/mikebtte
the 55-59 panels and burbs had a factory sway bar, might be able to find one and it'll bolt right up, they use the front spring mount for the ends and a pair of brackets for the body of the bar
Dang, well Ill have to take a look back in wyoming. I have yet to find a old truck at a junk yard here in california. Thanks for the input.
My YouTube:
Grandpa don't limit it to trucks since some fab will be needed anyway. Measure or estimate width and look at the muscle cars. Some had a 1" sway bar which should be stout enough for your 59.
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison
Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
Grandpa...call ESPO Springs N Things (800-903-9019) and check the web @ www.espo.com. They have springs, shackles, bushings, U bolts, front end kits, etc. and I'm pretty sure that is where I got a sway bar for my 57' BelAir.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Well ill look around and see if anything fits. If so ill share the info. If not I guess Ill get a new sway bar. Thanks for all of your help.
My YouTube:
The new after market ones area heck of a lot better than the stock ones Mine are 1 1/2 inch dia and cost about $150 each from
Brothers.
