2 members (porsche, Uncles51), 55 guests, and 4 robots.
Topics128,021
Posts1,055,357
Members48,420
#78325 06/02/2007 5:15 PM
V
V Offline
Can I use the orig. rearend with a 283 PG swap. 50 Chevy 1/2 ton? I have an S10 out of a 4wd but it is narrower. Thanks... Virg
#78326 06/02/2007 10:38 PM
Riding in the Passing Lane
No. Your PG will have an open drive shaft. You can put in the center section from a 55 up & an open drive shaft.
1972 Chevy c10 Cheyenne Super
#78327 06/02/2007 11:04 PM
yup, just measure first.
#78328 06/03/2007 1:19 PM
V
V Offline
My truck had an open driveshaft so I don't really know if it was the orig. or not. I have measured and the S10 is not as wide. Maybe about 2" shorter on each side....Virg
#78329 06/03/2007 3:11 PM
The open drive shaft rear end should work fine. Figure out what ratio it is. You may want to change to a higher gear. Are you useing an alum. PG or the old cast iron?
#78330 06/03/2007 5:05 PM
I am going to go out on a limb, but if your truck is a 1950 1/2 ton, you do NOT have an original rear end if it is open driveshaft. Also, the original rear end is closer to the width of the s-10 4wd. The non-original rear end you have under your truck is "too" wide. Nothing wrong with what you got. And I can't help you with the 283 PG swap.
Always get a 2nd opinion, especially if I am the source of the 1st opinion.
#78331 06/04/2007 2:19 AM
1950 1/2 ton would have had a torque tube set up originally.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#78332 06/04/2007 1:22 PM
V
V Offline
Thanks all....I don't know what gear ratio it is yet and I am running an aluminum PG.
By the way where can I get a tube and dip stick for a PG?
Thanks...Virg
#78333 06/05/2007 3:30 AM
Do a search here. There is a recipe for figuring out gear ratios by counting revs of your rear tires and your ring gear. Check it out.
~Jim
