| | | Forums66 Topics128,024 Posts1,055,393 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#78325 06/02/2007 5:15 PM | Joined: Jul 2006 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 92 | Can I use the orig. rearend with a 283 PG swap. 50 Chevy 1/2 ton? I have an S10 out of a 4wd but it is narrower. Thanks... Virg | | |
#78326 06/02/2007 10:38 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | No. Your PG will have an open drive shaft. You can put in the center section from a 55 up & an open drive shaft. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#78327 06/02/2007 11:04 PM | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | | | |
#78328 06/03/2007 1:19 PM | Joined: Jul 2006 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 92 | My truck had an open driveshaft so I don't really know if it was the orig. or not. I have measured and the S10 is not as wide. Maybe about 2" shorter on each side....Virg | | |
#78329 06/03/2007 3:11 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The open drive shaft rear end should work fine. Figure out what ratio it is. You may want to change to a higher gear. Are you useing an alum. PG or the old cast iron? They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#78330 06/03/2007 5:05 PM | Joined: Mar 2005 Posts: 311 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 311 | I am going to go out on a limb, but if your truck is a 1950 1/2 ton, you do NOT have an original rear end if it is open driveshaft. Also, the original rear end is closer to the width of the s-10 4wd. The non-original rear end you have under your truck is "too" wide. Nothing wrong with what you got. And I can't help you with the 283 PG swap.
Always get a 2nd opinion, especially if I am the source of the 1st opinion.
#78331 06/04/2007 2:19 AM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | 1950 1/2 ton would have had a torque tube set up originally. | | |
#78332 06/04/2007 1:22 PM | Joined: Jul 2006 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 92 | Thanks all....I don't know what gear ratio it is yet and I am running an aluminum PG. By the way where can I get a tube and dip stick for a PG? Thanks...Virg | | |
#78333 06/05/2007 3:30 AM | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Do a search here. There is a recipe for figuring out gear ratios by counting revs of your rear tires and your ring gear. Check it out.
~Jim
