6 members (dunfire, Bill Hanlon, stlcardinalsguy, Otto Skorzeny, papas52, Wayne67vert), 121 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
#783082 09/23/2011 1:44 PM
does anyone know what radiators with transmission cooler built in from other vehicles will work on a 62 c10 I am installing a 700r4 in mine and a trans guy said dont just put a oil cooler on the existing radiator or it will cook the trans. so i have looked around and new radiators are in the 380 to 470 range plus shipping. these are from coolcraft and lmc.just thought i would ask. thanks
beancan #783104 09/23/2011 3:01 PM
Here's recent thread that might help you. Different model truck, but the reference is the same.
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=781990#Post781990
Drew
beancan #783108 09/23/2011 3:11 PM
Give Champion Radiators a call. I'm very happy with them.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
DrewP #783110 09/23/2011 3:13 PM
A good, used original Harrison 4-core with the botton tank cooler, is a good replacement. I just had one re-cored, to stay with original equipment and it was close to $400.00. I have only found one supplier, that has a true-fit radiator. I found them at a swap meet and they were out of St. Louis, MO. I don't recall their name, but I purchased a few of their units, since they were so close to factory-correct. I have found the quality, fit, finish and configuration of the many aftermarket suppliers, to be average, at best.
We may have one, but I will have to check my inventory, to be sure.
I looked for a radiator for my 66 and found much the same as you, I then tried autozone and they had a copper/ brass, I think 2 core for $219.00. Seems to be OK I was going from a 6 cyl radiator to a V8 so they mounted in a different location and the size of my mounts were diffenent. Just a thought.
taclem
taclem #783328 09/24/2011 1:11 PM
Spectra from Summit has a 3 row that is an original fit for under $200 plus freight. I have one coming for my 64' and it should be an improvement over the 2 row I took out after 47 years of service.
Tramp
dj durant
More pix on Flickr
