4 members (klhansen, 37 GC, Hotrod Lincoln, Philipj), 92 guests, and 1 robot.
Topics128,143
Posts1,056,786
Members48,454
#781700 09/18/2011 2:43 PM
Good morning Stovebolters. Bringing our 1950 3600 back to life and have found that there was about half a tank of gas in the tank when it was put away 7 years ago.
Whats the best way to clean out an old tank and prep it for use?
Thanks - Bruce
If a new one is available, I always go with a new one, along with a sender and rubber hoses,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Second what Bigtrucks said. There is probably a lot of surface rust in the tank from moisture condensate. That's what happened to my truck. I decided to send mine to Tank Renu. A lot folks on here have used the tank "clean and coat" systems (available from a lot of vendors) with very good results. Good luck and keep us posted on your project.
Ex Hall Monitor
Ex Hall Monitor
If it's just old fuel it can be cleaned fairly easily. Many radiator shops will boil it out for you. If there's rust involved it'll need to be acid cleaned and coated. If that's the case I agree with Scott, replace it if you have that option.
I used a 3 step system from KBS coatings....I am very happy with the results.
Do something! Even if it's wrong!
I took mine to a place that dips radiators, car parts, and entire car bodies to get rid of the rust. The place was called Chem Strip. Don't know if it's a chain or what. My tank had been sitting for about 25 years with old gasoline in it. After dipping it was clean as a whistle and I haven't had any problems. I think it cost about 75 bucks.
1956 Chevy 3200
My truck arrived with a tank half full of very rusty water. I drained and flushed it. With nothing to lose, I put a shovel full of sand and gravel and some more water and shook it hard and rinsed more water through until it ran clean. This took some time and strength. It came up clean enough to use, but ongoing rust would be a problem.
Its been sitting dry for a while , while I restore the truck. I expect to use one of the available tank-liner type coatings. I have used them before in motorcycles with good success.
'47 Canadian RHD 1.5 ton truck
