Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
1 members (Truckrolet), 444 guests, and 1 robot.
Topics126,777
Posts1,039,268
Members48,100
Most Online2,175
Jul 21st, 2025
Last night I got the front of my truck reassembled. The front pan that sits at the bottom of the rad and attaches to the bottom front valance has 2 bolt holes that do not make any sense to me. They are on each side of the pan and are a threaded hole directed towards the wheel wells. I cannot for the life of me figure out what or why anything would be boltsed in this area. Please help.
It's not for a diagonal brace from the pan/inner fender to the valance? Neither of my trucks has an extra threaded hole, actually it looks like all the holes are just bolted through.
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
1924 Ford Model T Fordor
All the holes along the edge are just through holes that bolt to the front side skirts and front valance. Towards the back there is the large hole for the crank bar and on nearly the same plane off to each side are 2 threaded bold holes directed towards the wheel wells.
I think you are describing the hole for the diagonal rod brace. The topside is a welded square nut to a 1/2x2" strip of metal indented into the pan. On the bottom a 8-10" rod with flattened, drilled ends is attached. The rod leads to the bottom valance and fender. There is a metal stiffener bar there where all the panels and the rod meets. If that's not it, I'm clueless too.
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
Ya that could be it. So there is some sort of brace that bolts on inside the fender? Is this to prevent the fender from flapping in the wind? I put fiberglass fenders on so maybe I do not need this brace?
Do you happen to have pictures of this?
You'll notice a little L-shaped bracket that resides on the inner lip of the valance. Everything attaches to that. Yes, it strengthens the lower fender and valance. If your fender is flapping, there are actual fender supports that mount the outer fender by the wheel opening to the inner fender.
Rod
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
Does anyone have pictures of this?
It linked it under Rod above.
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
Hey 46,
I just put 7 pictures of the area your discussing on the following link. All at tear down. Do not have anything of the brackets bolted on to with the surround but look close and you can see the rusted outline of one on the drivers side. Hope it helps.
http://www.flickr.com/photos/dodsonbrett/sets/72157627608401951/
Cavebull
cavebull
Stovebolts - so easy even a Cavebull can do it.
https://www.flickr.com/photos/dodsonbrett/collections
Did the 41 have these brackets? My pan doesn't have these two holes.
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 9.222s Queries: 14 (0.211s) Memory: 0.6423 MB (Peak: 0.7302 MB) Data Comp: Zlib Server Time: 2025-09-22 06:09:48 UTC
Valid HTML 5 and Valid CSS
