| | | Forums66 Topics128,165 Posts1,057,010 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 5 New Guy | | New Guy Joined: Jan 2011 Posts: 5 | What hanging clutch and brake pedal assembly is best to use in my 51 Chevy half ton? I want to use a firewall mounted master cylinder and a cable for the clutch. Any info would be greatly appreciated. Thanks | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | I used the whole setup out of a 1973 GM suburban. Not sure how you could do the cable on the clutch though. I had to use the rod but cut and weld it to fit. If you want measurements to where I mounted it let me know. Browse around in my photobucket folders and you will find some pics. | | | | | Joined: Jan 2011 Posts: 5 New Guy | | New Guy Joined: Jan 2011 Posts: 5 | Thanks for the info. I really appreciate the help! | | |
