4 members (Rich'sToys, dt235sd, GMJim, 2-Ton), 145 guests, and 4 robots.
Topics128,167
Posts1,057,017
Members48,458
What hanging clutch and brake pedal assembly is best to use in my 51 Chevy half ton? I want to use a firewall mounted master cylinder and a cable for the clutch. Any info would be greatly appreciated. Thanks
I used the whole setup out of a 1973 GM suburban. Not sure how you could do the cable on the clutch though. I had to use the rod but cut and weld it to fit. If you want measurements to where I mounted it let me know. Browse around in my photobucket folders and you will find some pics.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
I used this one in my 51 Panel....
very stout under dash replacement bracket.
I have an automatic, but the shaft looks like it would
easily support a clutch pedal, too.
http://www.classicperform.com/Store/1947_59_Trucks/4753FBBD.htm
mike
Thanks for the info. I really appreciate the help!
