| | | Forums66 Topics128,154 Posts1,056,857 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#78256 05/31/2007 1:54 AM | Joined: May 2003 Posts: 183 'Bolter | | 'Bolter Joined: May 2003 Posts: 183 | While driving down the road at about 20 mph this afternoon, I started getting really bad noises and vibrations. I stopped, and when I tried to let the clutch out, there was lots of grinding of gears, and it wouldn't move. Called a tow truck, and when he pulled it up on his bed, the rear wheels weren't turning (even though it was in neutral and the parking brake was off). Actually, first the right one was dragging, then it started turning, and the left one started dragging.
Are we talking rear end problems?
Just a few weeks ago,the engine and transmission were rebuilt. Coincidence? This is a stock 52 Chevy halfton with the 216 engine and 3 speed on the column.
My dad always told me, "Don't force it, get a bigger hammer".
#78257 05/31/2007 2:06 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | BillyDon,
My money is on the universal joint. Maybe the shop that put the new engine and transmission in wasn't well versed in the finer points of a closed driveline.
Stuart | | |
#78258 05/31/2007 5:39 AM | Joined: Dec 2002 Posts: 3,445 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,445 | ouch.... jack it up, put it on jackstands and see if you can find any damage, leaks ect...
#78259 05/31/2007 1:41 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Stuart probably has it pegged. You might pull the cover off the rear end & have a peek. The shaft between the axles might have got loose. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#78260 05/31/2007 5:03 PM | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Originally posted by Wrenchbender Ret.: The shaft between the axles might have got loose. Are you thinking about the spider gear shaft? Sounds like a possible cause to me, the retaining pin or bolt could have been left out, then the pin slides out and destroys the pinion while locking up the rear. | | |
#78261 05/31/2007 10:42 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I would guess that the rebuilder left the lock plates off the universal joint retainer bolts and the thing loosened up and locked up on you. This would be at the joint between the transmission and the torque tube.
#78262 05/31/2007 11:02 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Originally posted by BillyDon: Actually, first the right one was dragging, then it started turning, and the left one started dragging. Wouldn't this indicate that the lock-up was ahead of the pinion and that the differential action was still working...or trying to work! Stuart | | |
#78263 05/31/2007 11:16 PM | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Yes, but depending on how the rear locks up it could cause the same symptoms. Say the spider pin worked out 3/4", enough to keep the spider gears on the pin, also enough to jam the pin on the pinion. In this situation the carrier would lock, yet the differential action would still work. Grigg | | |
#78264 06/01/2007 1:04 AM | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | I'm thinking rear end. Won"t the spider gear turn without the drive shaft. At least on side,???Huh. Had a brother with fo-d 4x4 lock rear end Kepper pin broke allowing shaft to sling out till it hit punpkin .... can you say LOCK UP and flat spot tires? | | |
#78265 06/10/2007 8:45 PM | Joined: May 2003 Posts: 183 'Bolter | | 'Bolter Joined: May 2003 Posts: 183 | Those of you who thought my problem was the universal joint were correct. It turns out the transmission shop that rebuilt my transmission and universal joint assumed the mechanic who would be reinstalling my engine and transmission would be taking the universal joint apart in the process. So they didn't tighten the bolts or bend the lock tabs. Unfortunately, he somehow managed to put the engine and transmission back in without doing that. The transmission guy was impressed, but thought the mechanic should have noticed the lock tabs weren't bent over.
Of course, the transmission shop thinks they did nothing wrong, and the mechanic thinks he did nothing wrong. But the mechanic agreed not to charge me for the labor if I pay for the parts (it bunged up the universal joint end pretty bad, and the bolts don't seem to have any threads on them anymore).
Thanks for all the feedback.
#78266 06/11/2007 1:58 PM | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | If the mechanic is agreeing to pay for labor, they are admitting guilt. I don't see why they don't pick up the whole ticket.
The tranny guy was wrong to "assume" that someone else would finish up something for him. That was stupid. He should agree to pay for the parts. | | |
#78267 06/11/2007 6:11 PM | Joined: Feb 2002 Posts: 61 Member | | Member Joined: Feb 2002 Posts: 61 | Oh joy.... the 'ol finger pointing.....
Agreed, the tranny guy should pay for the parts.... you did nothing wrong, but they are trying to save $$$. If not, the mechanic and the tranny mechanic should talk.... you should not have to pay anything.
1948 Dodge 2 ton 1950 GMC 1 1/2 ton 1952 GMC 3/4 ton
#78268 06/11/2007 6:30 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Kaliburz,
I am guessing what Builder is saying is that BillyDon contracted with someone one to repair his truck in exchange for money. The shop accepted his money in exchange for their labor and knowledge in the repair of his truck.
BillyDon couldn't fix it. The shop said they could fix it. The fix was incomplete because the shop didn't do their job properly...should BillyDon have to pay for the shop to learn how to do what the shop said it could do when it took his money! I think there should be some financial adjustment made. If the shop is reputable, there probably will be.
Doesn't there always have to be a person responsible...doesn't the buck always stop somewhere?
Stuart | | |
#78269 06/14/2007 6:33 PM | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | they should be paying for parts and towing. i work on food processing machinery and if i screw up i make things right: i eat parts and labor and go without lunch because i just spent my lunch money covering myself. | | |
#78270 06/17/2007 1:37 PM | Joined: May 2003 Posts: 183 'Bolter | | 'Bolter Joined: May 2003 Posts: 183 | All,
Things didn't turn out too bad. The only parts needed were the replacement bolts. The mechanic had a machine shop clean up the yoke at no charge, and didn't charge me for any labor.
