| | | Forums66 Topics128,078 Posts1,056,057 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 74 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 74 | Folks -
Continuing to work on any number of jobs with the 47 1 ton.... Bodyman said that the door hinges were worn, needed to replace the pins with oversize ones. I got those from American Classic.
How are the existing pins removed? I tried a hammer and punch and beat it like a rented mule. No luck, then I chickened out. Is this a job for a press and heat? I know I'll need to drill out the hinge halves to accept the oversize pins - anyone done this? It it a slip or interference fit? No instructions came w the pins, just the oversize pins.
TIA for innybuddy dats done dis and can shed some light....
John | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | yep, Joe has given you the best! | | |
