10 members (Johnny Rib, 68ironhead, 2-Ton, 1955 1 Series, JW51, baldeagle, Guitplayer, walter74, Eisenholtz, Peggy M),
104
Mod | | | Forums66 Topics128,038 Posts1,055,471 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 224 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 224 | Does anyone with the 4-stake hole bed know the distances between the holes? I'm looking at building a flatbed with woodsides that mimics the look of stepside bed with woodsides. Just want to know the spacing of the stakeposts.
Dave Baird 1951 Chevy 3803Foot starters are for Stovebolters and people who need a kick in the ...
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | It'd be a 9' 1 ton pickup bed you're looking to measure? | | | | | Joined: Jan 2002 Posts: 237 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 237 | my 1941 1 Ton stepside long bed has only two stake holes per side. It is the original bed.
On a flat bed I would go with 4 spaced evenly. | | | | | Joined: Apr 2011 Posts: 224 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 224 | Yep. The 9' foot pickup bed. I understand the 4 stake hole version is rare. Evenly spaced for a flatbed is kind of the plan, but I was just curious as to how the stepside bed spaced them.
Does anyone know if it only came on certain model years, i.e. Advance Design, Task Force, etc?
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | a 9' bed was available in the 40's, possibly earlier I'm not sure. I know AD trucks have 9' beds on 1 tons and have 4 stake pockets, mine has one of those beds. I've seen them on late 60's trucks but don't know any more or other years or how many pockets.
I can measure mine sometime if you like, don't know if they're evenly spaced or not?. Honestly though it would make a whole lot more sense if you just spaced yours evenly for your bed length.
Grigg | | | | | Joined: Jul 2005 Posts: 581 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 581 | This is from a 1946 1-Ton. They are the inside measurements: 52.25" across and 101.25" long. The holes themselves are 2.25" by 1.375".
Here is some more measurements taken from the outside front side rail to the center lines.
2.25" stake pocket 32.25" support 78.25" support 106" stake pocket 108.25" overall length
So the pockets are NOT evenly spaced if you had 4.
| | | | | Joined: Apr 2011 Posts: 224 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 224 | Thanks 641Workmaster! (nice pics btw.) I figured they wouldn't be evenly spaced.
I had a thought that it might be due to the placement of the rear fenders or the spacing of the cross sills. However according to measurements I have, they don't coincide.
Anyhow, 34.5" from center to center would be evenly spaced with the same amount of clearance for size of pocket and space on ends.
