| | | Forums66 Topics128,065 Posts1,055,870 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 66 | in a nut shell, could someone explain the routing of the external oil filter? I have to install and have an inlet on top side and of cource the bottom(i do not want to screw this up)thanks for the info....i just don't know how the lines operate and placement!! | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The inlet hose goes to the pressure outlet that the oil gauge is hooked to in back of the ex. pipe. You will need a T to hook up both of them. The bottom of the filter is the return. It goes to an outlet in front of the ex. pipe. Remove the 1/8 in. pipe plug & put a fitting or the hose in the opening. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | The hose from the bottom is the drain back into the oil pan. The hose goes from the bottom of the canister to a tapped hole about midway and low on the engine block left side. The side hole near the top is the pressure side and the line runs down to where your oil gauge line comes off, about 3/4 of the way to the rear of the block. Most filters I have seen also have a drain plug near the bottom if the canister but off to the side a little.
Chuck | | | | | Joined: May 2010 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 66 | thanks for all the info...i appreciate it. | | |
