0 members (), 80 guests, and 4 robots.
Topics128,062
Posts1,055,857
Members48,428
#780197 09/12/2011 8:34 PM
in a nut shell, could someone explain the routing of the external oil filter? I have to install and have an inlet on top side and of cource the bottom(i do not want to screw this up)thanks for the info....i just don't know how the lines operate and placement!!
Riding in the Passing Lane
The inlet hose goes to the pressure outlet that the oil gauge is hooked to in back of the ex. pipe. You will need a T to hook up both of them. The bottom of the filter is the return. It goes to an outlet in front of the ex. pipe. Remove the 1/8 in. pipe plug & put a fitting or the hose in the opening.
1972 Chevy c10 Cheyenne Super
The hose from the bottom is the drain back into the oil pan. The hose goes from the bottom of the canister to a tapped hole about midway and low on the engine block left side. The side hole near the top is the pressure side and the line runs down to where your oil gauge line comes off, about 3/4 of the way to the rear of the block. Most filters I have seen also have a drain plug near the bottom if the canister but off to the side a little.
Chuck
thanks for all the info...i appreciate it.
