1 members (5 Window 9434),
68
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 174 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 174 | Does anybody know of a vendor that sells the 1 3/8 bore wheel cylinders? or even a rebuild kit? and maybe not costing me an arm and a leg haha, LMC wants basically $100 a pop... correction, they dont even have the right size
| | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | I bought my front 1-Ton wheel cylinders from Lordco here I believe. I seem to recall that they were about $90. This was a couple of years ago. At the time, I don't believe they could get me rebuild kits. At least you shouldn't need to buy them for another 50 years or so.... | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Josh_51GMC, Raybestos p/n for front wheel cylinders is WC4358, Lordco warehouse is supposed to have three, Raybestos p/n for rear wheel cylinders is WC9325, Lordco shows no stock, Raybestos p/n for the repair kit is WK77, Lordco warehouse is supposed to have three. If you'd like to know what I can purchase them for, send me a PM. Hope that helps. | | | | | Joined: Jul 2008 Posts: 326 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 326 | RockAuto has the kits for $13.02
SimS | | | | | Joined: Apr 2011 Posts: 174 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 174 | Pm sent to 3B
and i've only found that rockauto has the 1 1/8 bore... but then again im not very good with online catalogues.. | | | | | Joined: Jun 2007 Posts: 100 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 100 | I got my 1 3/8" wheel cylinders for my 49 3800 from Chevs of the 40's. Hope that helps.
My new 1949 Chevy One Ton Dump Truck. Still have it but parked, needs a new motor. 1953 2 ton parts truck Long Gone 1957 GMC LCF On 75 Cadillac Eldorado Frame Updated Feb 2021 | | | | | Joined: Oct 2010 Posts: 91 Shop Shark | | Shop Shark Joined: Oct 2010 Posts: 91 | Jim Carter has them,i got mine for a 1946 GMC252 pretty sure they also have rebuild kits for them.Their phone number is 1-800-862-1913 also in links on this site | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I bought two of the new front wheel cylinders for my 51 1 Ton when I was putting it together. After I bled the brakes I gave the pedal full force and the pedal slowly went towards the floor and I heard a metallic crunching sound. When I removed the front drums I found that the Huck thread on one of the new cylinder caps failed and stripped. Looking at it really closely I saw that there was a lot of clearance between the male part and the female thread and the whole assembly was much lighter than the original. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I have found the aftermarket wheel cyls. for huck brakes to be junk. The cups dont turn smooth on the cyls. makeing adjustment difficult. I put kits in the old ones. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2011 Posts: 174 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 174 | i found a set a rebuild kits, just got to wait for them to be shipped in. One question i have about the cylinders is i've blasted them, honed out the cylinders the tiniest bit possible. and when i was just "testing" to make sure they went back together properly, the (i have no idea what it should be called) cap that has all the grooves in it that you can adjust? with the screw/bolt that holds onto the shoes. sits fairly loose onto the body of the cylinder, is this normal? | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | pretty much the case. I've not worked on any in a long time but there is usually a "bar" going across the cylinder that keeps the "wheel" from rotating by itself. Sometimes that little "bar" will help hold them in place. Another trick is to screw the "bolts" all the way out until you get the shoes on. If you screw them in it will have tension that will always be pushing back.
....now, as I said, its been a while on the old ones so if I'm not leading josh in the right direction someone please jump in here.
Josh, have you also checked the service manual. It seems long time ago I seen where the old mechanics had what looked like a set of spring pliers that would clamp on and hold them in place. Whatever it is you can do it. Take your time and stick with it. | | | | | Joined: Apr 2011 Posts: 224 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 224 | To hold mine in place I used cable-ties (zip-ties). When it came time to install the brake shoes, I just snipped the cables after the shoes were in place and pulled the cable pieces out. Some of the new wheel cylinders (I think the front cylinders) come with rubber bands instead. Same trick, just pulling out rubber band pieces instead.
Dave Baird 1951 Chevy 3803Foot starters are for Stovebolters and people who need a kick in the ...
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | It usually has a fair amount of clearance because it has to move everytime the brakes are applied. | | | | | Joined: Apr 2011 Posts: 174 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 174 | Alright, thanks everybody, and yes i do have a service manual i've been going back and forth between haha. | | |
