1 members (69Cuda), 73 guests, and 4 robots.
Topics128,096
Posts1,056,487
Members48,444
Newbie here with a question about rear end gear ratios. Building a '50 3100 with a '57 235 and a 4-speed manual tranny. The current rear is too wide and is a 6-lug (front end is now a 5 lug). Looking for a rear from a 67 - 79 Camaro, Nova, etc. Wondering what is the best gear ratio. Truck will be a daily driver, I live in New England so many hills, but also will be in the highway frequently. Was hoping for your thoughts.
Thanks.
Newbie
1950 Chevy 3100
That is a pretty comin topic around here. Do a topic search and read through some of the threads.
Most usually go for the 4.10 rear from 67-72 trucks.
Dave Baird
1951 Chevy 3803
I went from 4.11 to 3.55. Great for local highway driving.
Craig
go online and find a speed / rpm calculator, there are lots of them out there. Then figure the speed in which you plan to drive most in. Gear the truck so its in its power band at the speed you wish to drive. 235's are most efficient in the 2100 to 2300 rpm band. Gear it to high and the motor has to work to hard, to low and you are wasting rpm.
I would think a 3.08, 3.23, 3.42 would be about right with the 3.42 for real hilly and 3.08 for flatter ground.
I run a 3.08 with a 250 engine, its fairly flat and mostly highways so I can keep up at 70 pretty easy. Around town its a little doggy, but I can live with that. I changed out a 3.42 to the 3.08, highway driving was much easier and less stressful.
Joe
Previous topic
Custom search Read through this to find more topics on the subject, post back what you find.
Tire size is important too!
Riding in the Passing Lane
I think about 3.42 area would be about right. A lot depends on tire size but most are around 27-29in. in diameter.
1972 Chevy c10 Cheyenne Super
